Gabriel
    Re: Gabriel
    How do you plan to OOTA it without a flipper anyway?
    That's were a relatively large drum comes in
      Re: Gabriel
      More pictures of the wiring and weapon motor
        Re: Gabriel
        looking good what's the led beside the deans connector for?
          Re: Gabriel
          Power light
            Re: Gabriel
            aaahhh i see... so is that wired to the deans there, so when the removable link is fitted it lights up?
              Re: Gabriel
              The FRA build rules say
              Power Light
              All Featherweights, Lightweights, Middleweights, Heavyweights and Super Heavy Weights, must have at
              least one surface mounted non-filament power light that is illuminated when power is supplied to the robot
              (i.e. when the link is in). The power light can be any colour but must be non-flashing and be in contrast with
              it's surroundings.
              I use a 24v LED from Technobots the same type in all my robots Heavy and feather so if one
              breaks the spare I carry fits all.
              If you keep it near the link it makes it easier to see during activation and easier to wire up.
                Re: Gabriel
                Thanks, will that light be seen from out side the robot? or just when you look inside it to put the link in?
                • #23
                  Re: Gabriel
                  It's a safety light to warn arena marshals that the batteries are still connected to the motor circuits. So the first option - visible as far away as possible.
                  • #24
                    Re: Gabriel
                    Where do you get a holder for the led bulb like in the photo above. I have 8mm led s but a holder like in the photo above is a great idea. I've checked techno bots but can't find any.
                    • #25
                      Re: Gabriel
                      I use the same ones as Craig Does, they come already in that mount
                      This is them here:
                      http://www.technobotsonline.com/led-24v ... inent.html
                      • #26
                        Re: Gabriel
                        perfect need to order some then.
                        • #27
                          Re: Gabriel
                          Some more pictures showing the weapon speed controller. motor controller mount, I am thinking about weapon tether positions for the axe.
                          • #28
                            Re: Gabriel
                            Looking great
                            • #29
                              Re: Gabriel
                              Thanks
                              Because lots of the bits are from the New Tron things are moving quite quickly at the moment
                              soon I have to build the new drive systems for the wheels this will slow me down a bit
                              but there is no rush as we have no events to go to for a while.
                              • #30
                                Re: Gabriel
                                Some pictures of the drive unit for one of the wheels. The large belt pulley has the bearings fitted into it so the
                                stub axle will be fixed (just a bolt though it will be 12mm diameter so I don't expect it to bend!) also the wheel
                                retaining bolts will screw straight into it, so there is no need for a separate wheel hub thus saving weight.
                                the drive unit is the faithful Bosch 35w motor. this will be run at the standard 12v, the reduction ratio is
                                a little over 5:1
                                I am hoping it will prove a little more reliable than the expensive things that only lasted one fight!
