just the last of the welding to do, then it will take about a day to get all my parts inside, but then the job I have been trying to avoid, the trial and error of making the claws with the weight I will have spare.
that will be interesting, pics soon of bot without claws and not fully painted... hopfully
its in a absolute mess but i think with lain's creative thinking it would be able to get up and running again, and probably better than how it was for me
Did reckon anyone else would have an original Xbox in their room except me , also didn't think anyone else would use quite as many cable ties and we did either.
What sort of size is it? Doesn't look insanely big or anything. I always just use terminal blocks to test things rather than soldering it, just so you can disconnect it all more easily if its not going as planned.
Cicatrix is 44cm x 41cm x 10cm with the pusher pod on so not a massive difference. Its well within the weight limit too, looking to add some weight before Edinburgh, so could just stash the old Daiske inside the front pod .
Sounds like some good improvements, will be interesting it in action.
