Team Avenger build diary
  • #31
    Re: Team Avenger build diary
    Also as another update for no one who knows yet, im now a part of the team
    • #32
      Oh, my bad lian, we also have a new team member and we are having an official team meet this Saturday
      • #33
        The 1st matter of buisness, hello i guess lol
        • #34
          all my parts are now either ordered or here, now i just have to put it all together and make my claws
          • #35
            just the last of the welding to do, then it will take about a day to get all my parts inside, but then the job I have been trying to avoid, the trial and error of making the claws with the weight I will have spare.
            that will be interesting, pics soon of bot without claws and not fully painted... hopfully
            • #36
              Ok for my update, Matt has kindly given me the shell to Spike the Avenger with some parts. Heres some pics of it in my
              bedroom
              • #37
                its in a absolute mess but i think with lain's creative thinking it would be able to get up and running again, and probably better than how it was for me
                • #38
                  Little know fact: I stuck the top on sideways in that pic
                  • #39
                    oh, also, ill be able to do you some new decals with my dads sign printer, just chuck a couple of layers of clear varnish on it to keep it protected
                    • #40
                      Did reckon anyone else would have an original Xbox in their room except me , also didn't think anyone else would use quite as many cable ties and we did either.
                      • #41
                        Yep, ive had that old Xbox since 2004 and its still going strong
                        • #42
                          ye, its very large for a feather and looks in a complete mess, but i think lian will be able to get it running again.
                          the cable ties were from today when we tryed to do a system check for the parts for my new bot and it didnt work
                          something was up in the system that we just couldnt find. what ill probably do is dis-connect everything and re-solder it all back together properly
                          • #43
                            What sort of size is it? Doesn't look insanely big or anything. I always just use terminal blocks to test things rather than soldering it, just so you can disconnect it all more easily if its not going as planned.
                            • #44
                              the main shell is 43cm x 43cm x 10cm with the addition of the wedge
                              next weekend you will see it with a new 3mm stell scoop and 2cm steel sided all bolted on and it might be able to take a few hits from spinner
                              but the steel would only be mounted on 3mm polycarb, but eventually will be fully welded together and after that will be a full metal shell
                              • #45
                                Cicatrix is 44cm x 41cm x 10cm with the pusher pod on so not a massive difference. Its well within the weight limit too, looking to add some weight before Edinburgh, so could just stash the old Daiske inside the front pod .
                                Sounds like some good improvements, will be interesting it in action.
