Team Avenger build diary
  • Re: Team Avenger build diary
    That's all I can do really, I'm not going to try and get lev 2 running for kidderminster though
      ok, so seeing as Matt isn't able to, I've uploaded a couple of pics of his robots.
        Nice, looks like a good couple of machines you have to play with. I'm really starting to like flipping stuff around too .
          Well one dont work and one kind of works
            I have 4 that don't work and 1 that kind of works
              I need one to be working in a month and it seems impossible
                The only problem is that it turns a bit strangely when you want it to go straight? Impossible seems a bit dramatic for that
                  I have tried many things, and get my actuator working
                    Matt, you can see that those wheels aren't parallel, can't you?
                    Your problem is probably less to do with motor speeds & more to do with the fact that the wheels are fighting against each other.
                      Dodgy picture angle ceri, the wheels are level
                        Can't be, it isn't parallel with the paving slab it's sitting on -Top wheel is, bottom wheel isn't. Either your wheels aren't or the slab isn't square.
                          On closer looking, it does appear slightly off yet explain why it goes to the right?
                            Apart from the wheels, looks good. Hopefully you should be able to get it running in a straight line if you move one of the wheels and motors round slightly
                              funny thing is its fine in reverse
                                I can explain that:
                                Tank steering works on the principle of two drives equally parallel & exerting equal forces.
                                Your right wheel is angled inward which means the robot pushing into a counter clockwise spin & being the dominant force, is drifting the robot right. Your left wheel skids.
                                When the robot reverses, the right wheel is angled outwards & is the weaker force of the wheels. Right wheel skids & the bot generally follows the left wheels direction.
                                If there's some handy and it fits, map your drive out on square/graph paper. It'll help affix your drive down to a minimum of drift error.
                                You could use someone like me on your team, Matt!
