Team Avenger build diary
  • Re: Team Avenger build diary
    i would take x-terminator and make it competative again yet it will take a lot or fime and money to do it were as mr nasty would be ready to run and since its 6mm steel, i doubt it would need changing to hardox armour
      yeah, as far as I know all that would need changing would be the radio system and possiblly the batteries (im not sure what it uses)
        Ahhhh I see, didn't know that. The conversion should be fairly straight forward, just a case of pulling all the old stuff out and putting the receiver in instead. If you're using the older speed controllers, NCC boards I think it is, you will need to keep the receiver battery too. Just so that doesn't become a problem
        EDIT: From the pictures it looks like Mr Nasty is using 3 SLA batteries
          36v, 4wd, 4 bosch 750's rammer
          if RR allow slippers again, i would do a pussycat style spinner in 10kg... possibly
            not sure if there would be enough space for a disc, Mr Nasty looks quite compact, personally I'd put a tornado style scoop on the front
              If you wanted to swap the SLA's for NiCad's you might have the weight for a spinner, but the space would probably be the biggest issue. The scoop would work a treat, probably a better use of the spare weight.
              Have RR banned you from wearing your slippers?!?! the monsters..
                lol, funny
                  thanks for pointing out my typo tony
                  but a double wedge with a spike on wither would work
                    yeah, I'd probably try and make the scoop interchangable so other weapons could be put on.
                      interchangable with what though??????
                        erm,............a different scoop.
                          The spike possibly, not sure how its attached, but could maybe make it removable easily. Maybe even a lifter?
                          I've never tried a HW electric lifter, but if the batteries can be moved back/modernised it might be a possibility.
                            what about a V-styled scoop
                              well Cherub uses a 250w motor with a 500:1 ratio so its possible
                              v-style scoop... elaborate?
                                Like shunt had I guess. Good for clearing snow I suppose .
                                I know that its possible as far as hardware is concerned, but as Michael said earlier, its space thats the issue.
