Team Avenger build diary
  • Re: Team Avenger build diary
    the front of Shunt, the bulldozer effect? you get the idea
      v scoop at the back and scoop at the front?
      the possibilities are endless... until i hit the weight limit
        it weighs 90kg so only 10kg spare of weight
          for a HW, a nice amount of room to play with
            yep, and if the batteries are changed it could take an extra few kilo's off
              see how much it would cost/how much weight i would save i guess
                If they've not been charged since back in the RW days they might be dead anyway and need to be changed. Eric/Scar use SLA's, but they're tiny compared to the ones they used to use.
                  i guess its time for some ear bending of my parents
                    Tony has a point, as far as I know, Mr Nasty was last used back in 2004
                      Very strong possibility that they're dead then. I also very much doubt that you'll get 2 additional scoops added on with 10kgs of weight, especially if you're sticking with 6mm steel or Hardox, the scoop on my feather is around 2kgs and its only 430x10x5mm
                        Batteries will be knackerd, even if they have been kept charged. For something like Mr Nasty you would need Hawkers, you won't get away with using cheap ones as they won't deliver the current, so your looking £300 for a set of batteries.
                          Very much an idea ATM, I would have to find out cost etc from the guy
                            Matt, would you have room to store it though? HW's take up a lot of space.
                              Dunno, I did look at the dimensions but I honestly can't remember, I'll have to check
                                Mr Nasty is 26*95*80 cm. Good old wiki.
