Robo Challenge - Predator
  • Re: Robo Challenge - Predator
    The motor is as short as I can make it however looking at the drawings its about 10mm too high to fit in. The shoulder mount supports and the tail servo will now be cut out and modified to fit the arm mech bit of a set back but should be ok once its done. I just hope the drill motor is enough to self right otherwise the toys may come out the pram.
      Gearbox looks sweet James, What ratio did you go for in the end? Isnt it worth putting an astroflight on there?
        Ye i was tempted but with how expensive they are and easily it is to burn them out under high prolonged stress I thought it better to get with something cheap. Its the gear out of a drill gearbox so the same ratio as before.
          Wouldn't a couple of big servos cut it?
          Sorry to say it James, but when you put this into full combat, if it breaks, you're going to cry so hard. :P
            you could use 5th scale metal gear servos?
            looks great
              Servo's don't have enough speed and torque, needs a lot!
                yeh i suppose
                  Started to machine the arm mech mount until the mills shaft bearing locked up! Nice....
                  Had to clock it up in the manual mill and finish it by hand. This is how far I had got.
                    Machined the inside section now im band sawing the excess so I can machine the bearing pockets in the top and bottom
                      Back in the mill and Ive just pocketed out the bearing pockets. Our digital read out has a nice function where you tell it the diameter of the pocket and the tool and it calculates each of the individual xy coordinates. very handy!
                        Machining some of the profiles
                          Clocked up again to drill out the pivot holes
                            Machined all the back off to release the part from the block and now im just finishing some of the profiles.
                              Voila! arm mount mech complete finally. I just need to finish off the ball screw and drive motor then its ready to test the arms
                                looks good!
