Re: Robo Challenge - Predator
The motor is as short as I can make it however looking at the drawings its about 10mm too high to fit in. The shoulder mount supports and the tail servo will now be cut out and modified to fit the arm mech bit of a set back but should be ok once its done. I just hope the drill motor is enough to self right otherwise the toys may come out the pram.
