Robo Challenge - Predator
Re: Robo Challenge - Predator
I loved this machine 3 years ago when I first saw it as a beautiful (behind the scenes) project, (no offense intended)! to see it come to life is awesome, what i like is that it is great to just look at without it even moving,my single tooth spinner was originally excellently machined by you guys,and they are the future, a drum has no chance tbh (unless we breakdown) I like drums coz their different and if I had a wedge or flipper I'd worry a bit but against a single disk tooth spinner, they ain't got a chance in hell expect if we breakdown or my bad driving lol!
Looking awesome James.
It looks & sounds like everything runs real smooth on the video.
Just a thought, is there a way you can use the 3mm ti to double both as armour and a way to stiffen the chassis up further? Particularly the parts of the chassis which take the most stick when the disc impacts.
Thanks Gary, yes all the functions work but we had trouble with the cheap orange rx. The mid point drifted out so quickly within 30 seconds we couldn't trim it and not long after the stick range wasnt enough to stop it moving the arms and head. Changed it to a spektrum rx so I'm hoping its all ok now.
Cheers Sam. Yes definitely. Was hoping 3mm ti armour would take most impacts around the sides but all the front would probably need some hardox. If NST got into the neck area it would cause alot of damage. Im trying to stiffen it with some more bracing on the neck so it doesnt twist the head but I think it will need some real protection too. The tube is only 10mm od and 8.6mm id so its not going to stand up to direct hits argh. It will definitely be at the UK Champs, what happens to it after that depends on if it gets mangled and if the new robot gets finished.
