Re: Team Troubles Robot Projects
thanks for the comments
i've been doing a bit more today, nothing major thou, a bit of filing and thinking about the internal layout. my weapon motor speedo came today aswell so really i've got all in internals now, just a case of finishing the robots its self off
i've either got some 12 volt drills or some 9.6 volt drills, and im undecided on which to go with, with the 9.6 i could run those off a seperate battery pack from the drum batteries - the drum is going to run off 2 12 volt nimh packs,
if i went with the 12 volt drills and used another 12v pack thats another 750g where as the 8.4 volt ones are lighter------------ do any of you think its worth having a seperate battery pack for the robots drive? or is it just a waste of weight?
also aswell in the drill motors - well in the 9.6 ones anyway, im not sure about the 12v ones- theres some plastic gears are they likley to break?
