im currently building 2 new robots for the tag team champs in sept. 1 of which ill use in the main comp and the other whiteboards. so i thought i might aswell make a team thread type thing.
at the minute im seriously peed off, i've just letterally typed this whole thing out and my computers messed up and the page closed. so i lost everything i wrote so here it goes again.............................
one of the 2 robots im making has a pnuematic flipper called troublesome and the other has a spinning drum and is called trouble starter (i like the word trouble:P)
trouble starter was a robot originally designed before christmas, and was going to look like barberious 2 from the robotwars days, but since i started to seriously think about making a spinner around a month ago and asking gary aswell as jamie a serious amount of spinner related questions it as apparant this wasn't a great way to go. the main reasons being the drum would have to be HDPE plastic, 250mm dia, and around 400m in length and seeing as the pipe could only be brought in 6 meter lenghts at £219 and seeing as the drum would have to be replaced fairly often with it only being made from plastic i as put off with the design. so with that i started to jot down designs for the new version. after settling on 2 designs, i then scraped those and settled on a final 3rd design. which i started making the drum for today which is 20cm wide and at the minute weights 1.764g and is made out of 4 and a half inch steel pipe with 3.6mm walls WHICH KILLS YOUR ARM WHEN HACK SAWING IT. link to a picture below. the back of the robot is up to where the red spirit level sits.
the drum and the weapon motor in the pic are sat ontop of my other robots chassis base as they have similar shapes and sizes to their designs, both will have 2 drill motors for drive.
http://teamtrouble.sports.officelive.co ... arter.aspx
and her is a link to a pic of my other robot Troublesome (which should similar to the grim reaper from series 7), with all the parts layed out on the top. this robot has been in the same way for over a month now, because i hadn't made a flipper before so didn't realise the cost of certain parts so i had to wait for the money to become avalible to me. i will soon get a move on with this robot also.
http://teamtrouble.sports.officelive.co ... esome.aspx
ill post some more pics up on here when both robots look a bit more interesting in the comming weeks.
i also nearly finished my drag racer today
its not very good but i really want to concentrate my efforts on the robots but it should do the job.
