Im not sure a steam-powered robot would qualify either, strictly speaking, since it is described as an external combustion engine - ie the combustion occurs outside the pressure system. However, I am sure if somebody did come up with one then the rule would be modified to suit!
Funny you should mention that.......was working on a steam powered, self driving robot. Still on the drawing board, needs work but it might get into the arena before it stops working.
