12volt 5/2 valve
  • 12volt 5/2 valve
    hi guys, i am in need of a 12 volt 5/2 solenoid operated valve, anyone got a spare they want to get rid of please
    Re: 12volt 5/2 valve
    Only 24V 1/8bsp here, but a load of them.
    There are options tough.
    You're going to run 18V don't you? A 24V valve probably would fire on 18V.
    Other option is to boost the circuit for the valve.
    Or with a voltage booster, or with an extra battery.
      Chris,
      Busted has a 24v one and there's a little 9v square battery to boost the voltage to fire it.
      Do the same
        I used one of these, it worked fine, and its cheap - ran it at 11bar max, gave it a try up to 14bar but it leaked - instant gasket fixed it.
        http://www.ebay.co.uk/itm/DC-12V-4V4...item51a4a198e3
          ive ordered one from ebay china, only cost £7.39 and free postage so worth a play with just to see if it would be suitable. http://www.ebay.co.uk/itm/160675374094? ... 1439.l2649
            By looking at that valve, I realised there is another way to control most 5/2 valves.
            Most valves have a manual override. With some it's a press button, others use a turning switch. Most perfectly controlable with a servo.
              i think my bot busted/rip has the same set up, it works a treat,
