100mm FP ram and 2kg buffers
  • 100mm FP ram and 2kg buffers
    After doing some major upgrades of Bulldog so am after a new ram and x2 2kg buffers, please contact if you have anything of the sort
    Re: 100mm FP ram and 2kg buffers
    Buffers. I have several 2 kg CO2 bottles waiting for a new home.
    Ram, non ready.
    In short, I need dimensions to say more.
      May seem a vague question but whats the usual stroke length you make?
        Oh, I made in the past 100mm bore rams stroke 50mm, to stroke 358mm (the one in Tough as nails).
        It just depends on what is wished for.
        It happens to be that there is 1 ali ram for sale. Stroke 130mm (PM me about this)
          think you will also be wanting a new chassis if you put a 100bore ram in Bulldog! For buffers, just get hold of a couple of old fire extinguishers and re-tap the M25 thread in the top.
            That is the plan
              I retap the buffers with 3/4 BSP.
              More than enough meat, pressure tests up to 3000psi with ease. (the bottle I tested to destruction blew at 4600psi) And easy to get connectors for.
                I have an empty 2k fire extingusher, perhaps swap for something feather.
                DaveMac
