Batt charger
  • Batt charger
    Hi Guys
    Having just uprated the Bullfrog to 36v NiMh power packs (cheers Andy)
    I now have to get a suitable charger for them...
    Any suggestions ???
    Cheers Froggy
    Re: Batt charger
    so is one pack 36volt?
      Re: Batt charger
      yupp 28 cells per pack.....3 packs.
      Should go Whoosh...
        Re: Batt charger
        ok thought i might have a suitbale charger spare but nope to bigger packs :shock: :shock:
          Re: Batt charger
          Originally posted by froggy
          Hi Guys
          Any suggestions ???
          Cheers Froggy
          Take a bit of 1.5mm wire and wire two plugs into the packs so you can charge them half at a time with your existing charger. But will you listen........................
            Re: Batt charger
            Thank you mother twanky....LOL
              Re: Batt charger
              Dear Mother
              So effectively i would have to split the 3x 28 packs into 6x14 packs ...
              Hmm...1) ...more wiring to do
              2) ...expense and more connections to break
              3)....time it would take to charge that many packs
              SO.....back to square one..
              Can anyone recommend a 36v NI-Mh charger to me ??
              Cheers Froggy
                Re: Batt charger
                Cheers Froggy
                yes a astro flight
                112 Deluxe Charger/Discharger
                This Deluxe Digital Peak Charger/Discharger can charge any 2 to 40 cell Nicad or Nimh pack,
                from the tiny 50 mahr cells to giant 9,000 mahr cells. The 112 can also discharge these packs and measure their milliamp-hour capacity. Works from 12 V DC
                plug in turn to ammps charging and wait
                just over £100
                  Re: Batt charger
                  I've got the slightly different model of that astroflight charger. Basically same specs but it doesn't have the discharge feature. I may be willing to part with it as i'm going lipo in my next feather. Drop me a pm and we can talk.
                    Re: Batt charger
                    gary so how did u charge those A123`s ?
                      Re: Batt charger
                      By using a dapter with the astroflight charger. Basically it tricks the charger into thinking it's working with nicads and monitors the voltage of the A123s. Once it reaches a the appropriate voltage for the A123s it tells the charger that the pack is full.
                      http://www.slkelectronics.com/lipodapter/index.htm
                      It doesn't balance the pack but I never found a problem not balancing the cells. A132s can pretty much be treated like nicads and nimh in this respect.
                      If I shift this charger I may well shift the dapter too along with the A123 pack I used in hornet, interested?
                        Re: Batt charger
                        Toad
                        Actually we bought the Fusion Paladrin charger recently for £89.99. It does 1-30 NIMH packs as well. It come with a 12cell balancer which seem to sell on ebay for about £40.
                        http://alshobbies.com/shop/lookupstock.php?pc=35032
                        Andy
                          Re: Batt charger
                          What voltage are your batteries ?
                          because 28 cells is 33.6 volts.
                            Re: Batt charger
                            well the cells will be holding more than the spedificed volts so will probs be in excess of 36v when fully charged
