FBS braking + link system????
But what if you dont have the luxury of allowing your spinner to run out of power ? Like: people are in immediate danger, cant get away, spinner moving erratically ?
No, I for one will never allow the removable link rule to be bent. It exists for a very solid reason.
When you design/build a robot you should always put the link in mind first, dont save it as an afterthought. I would recommend that to any rooky roboteer... and some of the old ones.
Personally, the only way that seems safe to me is to put your link out of reach of your weapon, then out of the path of your robot, then see how you can make it safer still. Ideally the link would be accessible from all angles in all circumstances but it may never be, but strive towards that goal. The removable link IS practically the most important part of your robot.
