In practice a 20 cell NiCd pack is just under 2kg, a 10 cell A123 is 1kg so you should save over 1kg for 8 cell packs. A123 are far more difficult to solder, then you have the added complexity of balancing wires. The voltage drop under load is about the same as NiCds but watch out for the A123 temperature rise as they can very quickly reach their max working temp.
By using 3 packs of 8 cells instead of 2 of 12, the packs dont have to deliver as much current per pack and there is more surface area to keep the temperature down.
John, it is highly unlikely that Technobots will be selling them for high current applications like heavies, maybe for feathers and other applications but that depends on their balancing requirements.
Leo, I see, I did assume 3 packs of A123s and my concern over temperature rise remains. Basically, in my opinion based on my own bench tests from what I can remember as I dont have the results to hand, A123s can just about manage a 5 minute discharge in a freely vented area before exceeding 60 deg C. Their Ah efficiency does not appear to be as good as Bot-Packs so a 5 minute constant discharge is between 10-15C (15-33A). Forget the A123 claims of 35C constant. Bosch machines with a heavy nose drag like M2 need an average 90A for 5 minutes so three A123 packs is border line at best, 4 would be most likely but could be 5 packs if the temp rise in hot conditions was a problem.
I see. Doing my numbers on our feather Ive come to the same conclusion. 35C is not reachable outside lab conditions, let alone in a robot.
We run 4 A123s (so 13.2V) in our feather Hannibalito 3 (also a flipper).
With 2 speed 900s on the scorpion XXL I can do 2 fights back to back with it. The temperature is lukewarm at best so thats not much of a problem but the batteries are bone dry afterwards. I need to balance and charge them as soon as possible after that. So for 1 fight its fine, for 2 fights i would go with 2 packs for a feather like mine. I draw pretty much a constant of 20-25A.
