Lithium cell tests
  • Lithium cell tests
    So do I.
      I support it as well
        It seems the DRG is not opposed to the A123s in all weightclasses.
        What is the RFL view on the A123s?
        The Aussies use them actively for more than a year now. And no safety issue came up with them.
          i also support it
            Main question is: Whats taking it so long???
            Cells, chargers and balancers are commercial available. So is there any argument left to reject it?
            (Message edited by tough_as_nails on February 11, 200
              http://www.hobbycity.com/hobbycity/store/uh_listCategoriesAndProducts.asp?catname=LiFePo4&i dCategory=218&ParentCat=85http://www.hobbycity.com/hobbycity/s...cts.asp?catnam e=LiFePo4&idCategory=218&ParentCat=85
                Anybody any comment yet, why it would not be allowed?
                  gonna need um soon
                  gotta get a few packs
                  how much we talking?
                    i am just waiting for an answer just like you Jeroen.
                      I dont see any reason not to allow all robots to use them either. Yes they have issuses, but not safety related (at least no more than current batteries) and if people want to try them the worst that can happen is they damage them by incorrect use and loose money, but thats the roboteers choice. I guess it will come up in the next FRA meeting, if there are alot more interest then perhaps the FRA commitie can do this by Email to resolve it sooner.
                        What is the discharge rate like on A123s compared to good quality nicads?
                        I would possibly think about an upgrade but my nicads work well as it is and I wouldnt want to lose any performance.
                          http://www.flyelectric.ukgateway.net/lithium-a123.htmhttp://www.flyelectric.ukgateway.net/lithium-a123.htm
                          Suggests 30C
                          A123 Blurb ...copy & paste ..
                          Nanophosphate is a positive electrode material of remarkable rate capability, critical to high power systems. Our high power products are able to pulse at discharge rates as high as 100C and deliver unmatched power by weight or volume. With their low impedance and thermally conductive design, A123 cells can be continuously discharged to 100% depth of discharge at 35C rate, a marked improvement over other rechargeable battery alternatives.
                            as far as im aware they arent as good. Like its been said, theyre light weight and safe enough, but the performance is alittle bit dull unless you put some more in parallel
                              Its pretty simple, to get the same performance with nicad you need 3 Nicads since 1 A123 cell is 3.3V. Therfore much heavier. Good Nicads can however deliver more in short bursts than A123s can. But still, thats not a safety issue, that is up to the roboteer if that is sufficient.
                              I run Hannibalito 3 on 4 A123 cells in series (13.1V) with 2 Speed 900s for drive and I can do about 2 fights with them on 1 charge. So more than enough for 1 fight, and I have no complaint about performence. and for a 350 gram batterypack thats nod bad at all.
                                I think that there is enough interest to warrant expediting this and swiftly ending this long winded safety issue.
