22nd - 24th July European Championships 2005
This topic is closed.
  • #61
    If you want to discuss this further, I suggest you open a new topic in the general chatter area.
    • #62
      Due to negotiations with other parties in Amsterdam, I cant be more precise then: somewhere in the periode of 1 to 14 July. We will be running: heavy-, middle-, feather- and antweights.
      • #63
        Great news Marien hopefully well have our middle ready by then too so Team Storm will be along - done just about every other European event thats been run and for anyone who hasnt been to one.... theyre fantastic
        Id be more than willing to coordinate UK teams going over as I have done before, and if theres enough see if we can get some sponsorship to cover some of our costs.
        Ed
        http://www.teamstorm.comhttp://www.teamstorm.com
        • #64
          soz about my previous comments, quite a while back actually. I have this annoying habit of blindly poking advise into things...
          Anyway, good luck with the event.
          • #65
            Thank you Ewan..Just remeber to think before you post and well get on just fine!
            • #66
              it comes with age ewan your young ewan remember ur living in a world of old saggies like mike and geoff
              just smile after everything ewan ull get away with murder trust me
              • #67
                But Craig, Have you tried highlighing the , It soon becomes angry :sad:.
                • #68
                  highlighting the :sad: gives an even more hallowenish effect...
                  • #69
                    Are the Americans going to be invited?
                    • #70
                      Were going for European Championships first, Mike.
                      • #71
                        We will be testing the new machine from the Bulldog stable,should turn a few heads,
                        Nothing exceeds like excess!
                        • #72
                          Well my heads just been turned with a statement like that (hope it justifies it !!!)
                          Look forward to seeing it. Nobody seems to do excess or extreme any more.
                          Roger.
                          P.S. Hoping to have my Feather running for this event - Its a bit extreme itself.
                          • #73
                            Bulldogs new weapon is in my profile total weight
                            including teeth 18kgs,made from T6, with D2 tool steel teeth, 1500 rpm,
                            Der Boyz
                            • #74
                              Nice Tony.€¦ Very nice indeed.€¦ Any chance you could publish the dimensions of the disc so I can do a KE calculation!! :wink:
                              • #75
                                Hello Geoff
                                I have already done a calc before I made it but it will be interesting to get someone elses calc
                                Here goes,Dia across disc 500mm,Dia across teeth when in position 600mm, Disc 27mm thick,teeth 25mm thick,geared to 1500 (dependant on testing)
                                starting and stopping has to be considered!
                                Lem 130 prime mover Shaft dia 38mm,
                                tony
