Robo Challenge - 2013 FRA UK Featherweight Championships!
  • Re: Robo Challenge - 2013 FRA UK Featherweight Championships
    Originally posted by razerdave
    I hope I get to have a fight with Boner without us both becoming immobile at the same time :P
    Twice!
    That was hilarious, lol.
    I look forward to Yeovil as much as I do this, actually!
      Originally posted by typhoon_driver
      Other - Featherweight Champion 2013
      What you did there. I see it :wink:
        Name - 720
        Weapon - 3.2kg, 13000 rpm drum (new single tooth version being made) - castle creations powered
        Armour - 3.2mm hardox, 3mm stainless and 20mm solid alumec 89
        Drive - banebots p60- RS775 motor combo on 5s lipo
        Other - First to use botbitz escs in uk, fastest spinning weapon on a feather to date in the UK.
        changed slightly since the picture- has spikey stickey out bits, new drum bits and probably going to be black/green on the day lol
        Name - 360
        Weapon - 5KG 360mm disc- scorpion powered.
        Armour - 3mm aluminium check plate over 2.4mm gr4 titanium mono chassis
        Drive - bosch 35 - with hand carved brass gears :P
        Other - First Brushless feather in the uk, previous best engineered robot, featured on the gadget show
        360 for whiteboards/demo only
          Nevermind
            Read the bit below the picture of 360. In bold. :wink:
                Hey we made a brushless Ploughbot first! Lol
                So you have seen the entry list, before the draw starts who do you think will be in the top ten?
                Here's my guess -
                Nst
                Explosion
                Vortex
                B2
                Drumroll
                Lf3
                Galactus
                Tiny Toon
                Ls4
                Predator ... Possibly?
                  NST,
                  Boner,
                  Satanix,
                  Predator (easy heat - see Venom 2012),
                  Tormenta,
                  Rip off,
                  Cobalt,
                  Tiny Toon,
                  Inertia XL
                  Explosion FTW
                    Weight: 13.5kg (I think, really should weigh it)
                    Drive: four Argos drill sets, 24:1 gearing with gimson 18v motors running at 6s
                    Weapon: none, just a simple parallelogram inevitable wedge
                    Armour and Chassis: fully welded 5mm steel front, back and sides. 3mm steel top and bottom
                    Notes: is my first champs, just plan to survive and come home intact
                      Do the Gimson motors just replace the Argos ones? I assumed the Argos motors would have some bizarre standard of pinion gear.
                      I also assumed they would have a 36:1 gearatio.
                        Yup! You use the spare parts that gimson robotics offer to change the ratio from 36:1 to 24:1. All the motors on sale should fit too.
                          Ah ok, so the only thing that remains from argos is the plastic housing.
                            The plastic housing, axle bit, 2nd stage gears and sun gear. Basically your chaging the motor, pinion, first stage gears and gear carrier.
                              Ooh that's good to know. First stage on my 18v drills are plastic so looks like I should be able to swap them out and get a more desirable gear ratio.
                                If anyone missed out of the champs please do let me know so we can add you to the reserves list. Most importantly if anyone will need to pull out please let me know asap as there are teams really wanting a place. We currently have to find a space for Turisas as their entry didnt come through until after sign ups closed.
                                The current reserves list is -
                                Shane Swan
                                Push n Shove
