Robo Challenge - 2013 FRA UK Featherweight Championships!
  • james...venom
    replied
    Re: Robo Challenge - 2013 FRA UK Featherweight Championships
    within the next 2 weeks.
    Leave a comment:
  • botmad
    replied
    When would you be doing the draw james ??????
    Shane (team tilly)
    Leave a comment:
  • james...venom
    replied
    Yes it did Dan, do you need to make changes?
    Leave a comment:
  • Danjr1
    replied
    James,
    Did the entry form have a space for the names of team members or how many we are bringing along?
    Leave a comment:
  • james...venom
    replied
    If anyone missed out of the champs please do let me know so we can add you to the reserves list. Most importantly if anyone will need to pull out please let me know asap as there are teams really wanting a place. We currently have to find a space for Turisas as their entry didnt come through until after sign ups closed.
    The current reserves list is -
    Shane Swan
    Push n Shove
    Leave a comment:
  • PJ-27
    replied
    Ooh that's good to know. First stage on my 18v drills are plastic so looks like I should be able to swap them out and get a more desirable gear ratio.
    Leave a comment:
  • Danjr1
    replied
    The plastic housing, axle bit, 2nd stage gears and sun gear. Basically your chaging the motor, pinion, first stage gears and gear carrier.
    Leave a comment:
  • PJ-27
    replied
    Ah ok, so the only thing that remains from argos is the plastic housing.
    Leave a comment:
  • Danjr1
    replied
    Yup! You use the spare parts that gimson robotics offer to change the ratio from 36:1 to 24:1. All the motors on sale should fit too.
    Leave a comment:
  • PJ-27
    replied
    Do the Gimson motors just replace the Argos ones? I assumed the Argos motors would have some bizarre standard of pinion gear.
    I also assumed they would have a 36:1 gearatio.
    Leave a comment:
  • Danjr1
    replied
    Weight: 13.5kg (I think, really should weigh it)
    Drive: four Argos drill sets, 24:1 gearing with gimson 18v motors running at 6s
    Weapon: none, just a simple parallelogram inevitable wedge
    Armour and Chassis: fully welded 5mm steel front, back and sides. 3mm steel top and bottom
    Notes: is my first champs, just plan to survive and come home intact
    Leave a comment:
  • psychostorm
    replied
    NST,
    Boner,
    Satanix,
    Predator (easy heat - see Venom 2012),
    Tormenta,
    Rip off,
    Cobalt,
    Tiny Toon,
    Inertia XL
    Explosion FTW
    Leave a comment:
  • james...venom
    replied
    Hey we made a brushless Ploughbot first! Lol
    So you have seen the entry list, before the draw starts who do you think will be in the top ten?
    Here's my guess -
    Nst
    Explosion
    Vortex
    B2
    Drumroll
    Lf3
    Galactus
    Tiny Toon
    Ls4
    Predator ... Possibly?
    Leave a comment:
  • psychostorm
    replied
    Leave a comment:
  • RogueTwoRobots
    replied
    Read the bit below the picture of 360. In bold. :wink:
    Leave a comment:
