2012 FRA UK Featherweight Championships by RoboChallenge
  • Re: 2012 FRA UK Featherweight Championships by RoboChallenge
    Laser 2 - A 4wd ram bot with an electric lifter capable of lifting 50+kg
      James can you change Flow to Cobalt please
        Johnny 2x4- A 2wd wooden wedge bot. More details can be seen here viewtopic.php?f=240&t=4922
        Speaking of wood, are there any other wooden robots? Not even my spiritual timber homeboy Block of Wood is there. So that 12 page thread in General Chat was for nought. :P
          Tormenta (means Thunder in Spanish) (name may change...)
          100mm wheels, 4x 12v drills at 18v, chopping board everything (varying from 5mm up to 20-25mm), electric 4-bar lifter.
          Don't be fooled, it is made with really strong sellotape and really good rubber bands. :wink:
            Doorstop: 2wd, 4 speed 900 replicas, 22.2v, 6-20mm HDPE invertible wedge
            Why are we doing this?
              Kaizer: Invertible 4 wheel drive robot with screw thread powered lifting forks. Based on former Welsh Robot Wars champion Panic Attack, this machine represents Wales for the competition.
                Originally posted by james...venom
                I'm not aware of what many of these robots are like. If your entered could you please post a little bit about your machine so everyone knows what the competition is like. Thank you very much. I shall start -
                Because James said so. :P
                  Originally posted by razerdave
                  There are a few unrecognised names in the comp this time, like 'Conker'. Anyone want to own up to that one?
                  I think thats what shrapnel is now called, of eventorizon fame :wink:
                    TS2- as of the minute a 2 wheel drive spinner.
                    3.5kg beater style weapon powered by a speed 900
                    may be rebuilding the chassis yet which will totally change the robot but will have to see
                      Metalbeak: 2x Drill Motor drive, 12v, 8-10mm HDPE armour, FP Pneumatic Flipper.
                      Highly untested and needs to be redesigned
                        Chuck.....I dare not describe it as it will hunt me down and kill me.
                          Not that I'm complaining, but how the hell did Drumroll manage to get 10th seed? It was utter cack last year!
                          Anyway, Drumroll: 2WD drum spinner, 15mm Nylon chassis and 4-6mm steel armour. Weapon weighs 2.3kg and is powered by a Scorpion brushless motor.
                          Carcinus: Unconventional (and possibly epic fail) three-wheel drive crab-bot, running 12V drills on 19.2V. Steel claws are only static, but will flash by in a blur as the robot heads straight for the pit
                            Double post
                              Omen-
                              A 2wd single toothed disc spinner, runs 2 speed 700 drive motors on 130mm wheels and has a speed 900 driving the 2.6kg 330mm disc.
                                Invictus- speed 900 powered drum running on 24v, 20mm hdpe armour, drill motor drive, aluminium lid and base
                                Centrifuge- horizontal bar spinner powered by replica speed 900 motor off 12v. Drill motor drive, 20mm hdpe armour and 3mm steel base and lid. Not built yet by should be fairly simple.
