I`m trying to get a gyro set up but as usual I`m going round in circles (ouch!)
I can`t find any info on setting it up for a robot/car, nothing on youtube.
I have done what I think should make sense but the robot just keeps pulsing in a circle.
I have it plugged into the RX steering channel (3) then into the tail mixer, I'm using channel 2 for the throttle.
From the tail mixer I`m going to two escs, one to run the drive on each side.
The gyro is a HK401B http://www.hobbyking.com/hobbyking/s...dproduct=26075
Is there a way to set it up for use in a robot? We used one in 13Black but that was soooo long ago
The gyro has a RX connector with just a signal wire in it which I believe is plugged into a switchable channel to turn it on and off, I have plugged that in to some of the channels but it doesn`t seem to do anything.
I will bring it to the Iron Games tomorrow anyway if anyone can help there.
