just a thought
  • just a thought
    could u get a servo and take the controller part out and where the motor goes some how add more power to control a 12v motor?
    esc----batt----motor ????
    or is this stupid
    Re: just a thought
    this + that = Bidirectional ESC
      Re: just a thought
      what dose that mean?
        Re: just a thought
        The first link is how to get directional control from a servo and some relays.
        The second is how to control speed from a servo and a transistor (should really use a mosfet).
        Finally is the amalgamation of the two to produce a speed controller that can reverse.
        If there's anything specific you don't understand about it don't hesitate to ask.
          Re: just a thought
          sorry for delay on reply laptop broke -_-
          here is what i thought
            Re: just a thought
            servo board's dont like bigger motors than they are desighned to handle
              Re: just a thought
              That design won't work, you can do just do a straight motor swap but you can't really have a particularly big motor on a servo board, only one of similar size or smaller. It'll be fine for fleas, ants and possibly beetles.
              Some larger servo's have a separate H Bridge IC in them that can take more voltage than the control electronics so you can over volt them more like so: http://www.teamkiss.com/antweight.html (bottom bit of the page)
              To run a bigger motor you need to use relays and/or mosfets/transistors to take the current.
                Re: just a thought
                ok just tryed motor swap for another small motor and it works!
                whats the motors that most ants use? one with the gearbox?
                  Re: just a thought
                  Yeah, pretty much every antweight uses 12mm gearbox motors like these:
                  http://www.robotbits.co.uk/motors-gearb ... od_10.html
                  These are the ones all my robots use. The HP motors are the best of these type of motors, more power that ones of a similar type.
                  However, if you are on a budget:
                  http://www.ebay.co.uk/itm/6V-300RPM-Tor ... 3366bf48bd
                    Re: just a thought
                    thanks there the ones ive seen
                      Re: just a thought
                      ive got a cheap rc car and i tryed the servo board on it and it works! might put a vid on youtube!
