Just so I dont take the other thread totally off topic I will start a new one.
I dont mean to cause a fuss with this by way of changing a bunch of things all at once. But this has direct effect of the weight issue. As I understand it you weigh the robot with an empty tank. Here you weigh them full. That is a bit of a problem, dont ya think?
Also, if a meeting is required to change something why not discuss two things at once so you dont have to set up another meeting which will take more even more time, ECT...
You, the FRA should not have to change much if anything. The way I see it you, the FRA and UK have the most pneumatic robots. You seem to have a safe way of doing everything which has led to some awesome pneu bots! Here in the USA we have, ummmm what, one SHW good pneu bot? Everything else I would not even call good when put up Vs. your pneu bots. I cant even think of a feather pneu bot off the top of my head that is even worth naming.
Thus all I suggest is that you make a movement that the RFL adopt your pneumatic rules just as we have asked you to adopt a new weight class system. All it would require is for a boss to send an E-mail to Dave to get the ball rolln. I am going to make a post in my forum about this as well.
~Chad :-)
~Chad :-)
