Re: Gimson Robotics
I'll certainly look into the freewheel mounts - for the front section of the gearbox, second bearing with housing plus shaft you'd be looking at around £12. I've got lots of other work on at the moment though so can't promise this as a product option any time too soon.
Gary, I am somewhat reluctant to sell the gearbox housing separately as it doesn't fit all small drill motor ring gears (most I've used in the past have a larger outer diameter and simply wouldn't fit the mounts without re-cutting), nor does the motor mount fit all 550 motors without increasing the central bore. There comes a point when I can be offering too many product options and if they're not all compatible with one-another then there'll be problems. So maybe in future, not for now.
