Velociraptor's Fanfic Tournament - Series 7!
    Velociraptors Fanfic Tournament - Series 7!
    The real Robot is Overkill.
    ORKA MK4
    Weight: 100 kilos
    Body Shape: Behemoth
    Speed: Some 15mph
    TC: 0
    GC: 2mm, 0mm at front.
    Wheels; 6 inner
    Armour; 7mm titanium
    Power; 3x 12v batteries, powered by a couple of Magmotors
    Colour; Black with white patches
    Weapons; A Behemoth like bucket scoop, made from titanium, and quite capable of lifting 300 kilos. It has a claw like device to grab an oppodent, like the claw on Mantis. The scoop is pnumatically powered, and has about 45 odd flips.
    Srimech: It has a dorsal fin on top used for self-righting
    Inspiration; Ive always liked Orcas. Adding the K made it sound more dangerous.
    Strengths; Weapon
    Weaknessess: Hard to turn
    BIO
    Every big team needs some big star to bring in the crowds. My big name is Orka MK4, representing Team Dinowarrior in all its glory.
    No one is faster, smarter or more agile than Orka Mk4. When charging, other robots need to get out of his way. He can flip just about ANYTHING that doesnt take the warning, or simply grab hold of them. Hes ready for battle! Are you?
    DIE-CERATOPS RE-INVERTUS
    Weight; 100 kilos
    Body Shape: Wheely Big Cheese
    Speed; 15mph
    TC; 0
    GC; 0mm at front, 3mm at sides and back.
    Wheels; 2 inner, sticking out only slightly,
    Armour; 8mm titanium
    Colour; Green, with Killer Carrot style wrinkles, mouth and eyes. One of the eyes has a plaster over it, the other is a black eye. A few bandages are painted on this time.
    Weapons: A huge Wheely Big Cheese style flipper, capable of flipping a tonne or so.
    Srimech; As the name suggests, the robot runs inverted. Bars prevent side strandings, and the back is rounded, so stranding THAT way is outta the question. The flipper works upside down.
    Inspiration; Ive always liked Dinosaurs. This is a pun of Triceratops. The Invertus part is pretty obvious.
    Strengths; The ability to work upside down and still be able to use its weapon, now easier to control.
    Weaknessess: Tengu VI
    BIO
    Orkas cute-on-one-side-pure-hell-on-tuther friend, Die-Ceratops is equally as powerful and as nippy as his buddy. In the arena, he can get to oppodents/victims in record time. Then, once his flipper is underneath them, they can kiss the ground good-bye. Of course, hes teamed with me, and I can be rather protective over him...
    CYCLONE FORCE 2.5
    Weight; 100 kilos
    Body Shape; Storm 2
    Speed; 25mph
    TC; 0
    GC; Side is 0mm due to skirts. Back is 2mm. See set-ups for front GC
    Wheels; 6 inner
    Armour; 7mm Titanium.
    Power; Similar stuff to what Storm 2 uses.
    Colour; A blue-ish grey tone all over.
    Weapons; The robot has 5 set-ups, 2 brand new...
    SET UP 1...A lifter device, similar to Storm 2. In theory, it can lift 190 kilos. The front makes a wedge and results in a 0mm GC. However, the wedge is useless upside down.
    SET-UP 2...A pair of Kan Opener style claws, with about 4 tonnes of pressure at the tip. Front GC for this and Set-up 3 is 1mm.
    SET-UP 3...A Disc-O-Inferno style disc, reaching speeds of up to 3000rpm and with similar damage capability to this dangerous bot (I mean, look what it did to Panic Attack).
    SET-UP 4...Two 30cm long spikes, which, combined with the speed of the robot, can easily penetrate weaker armours (Id say anything 4mm thick or less, minus Steel, is in a bit of trouble).
    SET-UP 5...The most risky approach, A simple bucket scoop, like X-Terminator. The scoop is static, but can get underneath virtually zero ground clearance. Its front is 0mm.
    Srimech; The robot runs inverted, the sides are protected by the skirts and back stranding is impossible. Set-ups 2, 3 and 4 work upside down.
    Inspiration; The original Cyclone was named because it is the name of a storm and it sounds threatening. The force came later, after it became a pusher.
    Strengths;Raw power
    Weaknessess;Lack of control, Set-ups 1 and 5 do not work upside-down.
    BIO
    When Cyclone Force 2.5 is in the game, every other piece of metal is scrap! Cyclone can travel across the arena with great speed AND power. His interchangable weapon system means NO ONE is safe. Thank goodness hes harmless when turned off.
    LEPROSY INFECTION
    Weight; 100 kilos
    Body Shape; Tetanus Booster
    Speed; 18mph
    TC; 0
    GC; 2mm
    Wheels; 4 inner, top sticking out. Wheel flaps are situated either side of the wheel to protect them.
    Colour; A disgusting shade of lime green.
    Weapons; A very large, very dangerous vertical drum, capable of reaching speeds of 4000rpm. The teeth on the drum are curved upwards so they can flip as well as damage and very sharp at the tip. There is a reason for this...
    Srimech; The robot is invertable. Bars along the side and back prevent stranding. The wheel flaps, both on top and bottom, are set so the robot can still run inverted without getting stranded. Once upside down, the teeth of the drum gouge out robot parts.
    Inspiration; Named after the disease which causes the skin to flake and fingers and toes to drop off...namely because the robot does something similar. The basic idea came from an episode of The Simpsons.
    Strengths; Drum, control is pretty good
    Weaknessess; Wheels may be vulnerable to axes
    BIO
    When youve got sharp teeth, sickeningly bright green paint and a name of a skin disease, battle invitations are pretty remote. So, hes loving life in the Robot Wars arena where he can make others sick. Leprosy Infections drum is killer! And when hes upside down, those teeth start gouging out his prey. Grrr...
    MEGA MASHER 2
    Weight: 100 kilos
    Body Shape: Minion
    Speed: 12mph
    TC: 0
    GC; 0 at front, 1mm at sides due to skirts.
    Wheels; 4 inner.
    Armour: A nice 3mm of steel
    Power: Similar stuff to what Tornado uses.
    Colour: Red and yellow.
    Weapons; The front is a wedge, and the back has a nasty vertical disc, powered by its own motor and spinning at 2000 rpm. It can probably flip as well as damage. A side Minion style bar comes out from the side.
    Srimech: The aforementioned bar rights the robot, even though it can run inverted.
    Inspiration; This is probably the only robot I have where I have had no inspiration. It just came as a good name.
    Strengths: Power, weaponary
    Weaknessess: A little bulky, not as heavy as the body would suggest.
    BIO
    Mega Masher is still hell bent on robot destruction. Whether you think of him as the baddest, most brutal robot ever or just a power crazed crazy thing - just dont tell him when his disc is spinning at full throttle! His wedge is also dangerous; being one of the lowest out there. Dont trust this robot to lose as far as you can throw him! Even better, dont try to throw him at all; hes based around Battlebot champion Minion, and way too bulky for flipping.
    AXE-O-LOTL
    Weight: 100 kilos
    Body Shape: Comengetorix
    Speed: 20mph
    TC: 0
    GC: 2mm
    Wheels: 4 inner
    Armour: Mainly aluminium (5mm) with 3mm Titanium top plates.
    Power: Same stuff as Storm 2 and Cyclone Force uses.
    Colour: Has interchangable panels. One set is pure black, the other pure white with pink tinges.
    Weapons: A very nasty axe, with the power of Dominator 2. The head is diamond tipped, and the whole weapon is VERY persistant. It can fire about 40 times in one fight.
    Srimech: The axe rights the robot. The robots body is designed so it cant be side stranded.
    Inspiration: My favourite amphibian, the axolotl.
    Strengths: Powerful weaponary
    Weaknessess: Questionable armour.
    BIO
    Axe-O-Lotl likes a bit of Mexican chilli powder with his lubricating oil. After a break in Mexico, Axe-O-Lotl has returned to join the mightiest of the mighty on Team Dinowarrior. His powerful/persistant axe is brutal, and he has just as much power as Cyclone Force.
    OBLITERATION
    Weight: 100 kilos
    Body Shape: Revolutionist
    Speed: 5mph
    TC: 0
    GC: 5mm all the way round. It has to be.
    Wheels: 8 inner (4 on top, 4 below)
    Armour: 7mm titanium
    Power: It drives on 3x 12v batteries plus a couple of Magmotors. For the weaponary, the power matches Phrizbee.
    Colour: Dark blue with tinges of black and brown.
    Weapons: This robot is a full body spinner. The teeth are increibally sharp. It spins at about 500 rpm, and does damage similar to Phrizbee.
    Srimech: Unusual for a FBS, this robot runs inverted.
    Inspiration: It sounded cool. It also sounds like a ride at an amusment park, if you ask me.
    Strengths: Body! Need I say more?
    Weaknessess: Rather slow, First timer
    BIO
    Obliteration has the disposition of a train wreck many times over. Though he prefers to take his time around the arena, his super powerful spinning body delivers a nasty blow. Obliteration is a first stringer, and considers himself A closer - And he doesnt like having his photo taken for some reason! Watch out for this guy - hes no sweet pleasent ride let me tell you!
    ANNIHILATOR: Orka MK4 and Axe-O-Lotl
    CHALLENGE BELT: Cyclone Force 2.5
    HOUSE ROBOT REBELLION: Obliteration
    ANTWEIGHT: Tyr-Ant-O-Saw-Rus Rex
    FEATHERWEIGHT: Ram Raider
    LIGHTWEIGHT: Little Big Bot
    MIDDLEWEIGHT: Tom
    SUPERHEAVYWEIGHT: Octo-push 2
    Stats for these hopefully this weekend.
      Flaming Hell (Dave Weston)
      Hell Machine (Dave Weston)
      Sheer Hell (Dave Weston)
      Flipping Hell (Dave Weston)
      Jaws Of Hell (Dave Weston)
      Helliant (Dave Weston)
      All Hell (Dave Weston)
      Razer (Dave Weston)
      Wedge Devolution (Steven MacGregor)
      Killotine: EVO (Steven MacGregor)
      S.D. IV (Steven MacGregor)
      Whirligig 4.0 (Steven MacGregor)
      Revenge of the Revenge of the Bludgeonator! (Steven MacGregor)
      Toby the T-Ram Engine (Steven MacGregor)
      Tails (Steven MacGregor)
      Chaos 2 (Steven MacGregor)
      SUNCUST (Anthony Politzi)
      Shovearoud 2 (Anthony Politzi)
      Cyberdemon (Anthony Politzi)
      Psycho Cyan Evolved (Anthony Politzi)
      Bloody Tears 2 (Anthony Politzi)
      Judo Chop! (Anthony Politzi)
      Mr. Slave 2 (Anthony Politzi)
      Spawn Again (Anthony Politzi)
      Beta (Martijn Benschop)
      (Martijn Benschop)
      (Martijn Benschop)
      (Martijn Benschop)
      (Martijn Benschop)
      (Martijn Benschop)
      (Martijn Benschop)
      (Martijn Benschop)
      Firestorm V (Kevin Smith)
      Storm 2 (Kevin Smith)
      Mute (Kevin Smith)
      Atomic (Kevin Smith)
      Gravity (Kevin Smith)
      Dantomkia (Kevin Smith)
      Wolf (Kevin Smith)
      Enterprise (Kevin Smith)
      (Daniel Stickler)
      (Daniel Stickler)
      (Daniel Stickler)
      (Daniel Stickler)
      (Daniel Stickler)
      (Daniel Stickler)
      (Daniel Stickler)
      (Daniel Stickler)
      (Martyn)
      (Martyn)
      (Martyn)
      (Martyn)
      (Martyn)
      (Martyn)
      (Martyn)
      (Martyn)
      Overkill (Chris Mason)
      Orka Mk4 (Chris Mason)
      Dieceratops Reinvertus (Chris Mason)
      Cyclone Force 2.5 (Chris Mason)
      Leprosy Infection (Chris Mason)
      Mega Masher 2 (Chris Mason)
      Axeolotl (Chris Mason)
      Obliteration (Chris Mason)
      MW
      Hell Fire (Dave Weston)
      Killoteeny (Steven MacGregor)
      (Anthony Politzi)
      Tom (Chris Mason)
      LW
      Hell Hound (Dave Weston)
      Minigig (Steven MacGregor)
      (Anthony Politzi)
      Little Big Bot (Chris Mason)
      FW
      Hells Angel (Dave Weston)
      Aries (Steven MacGregor)
      (Anthony Politzi)
      Ram Raider (Chris Mason)
      AW
      Baby Hell (Dave Weston)
      Wedge 3mm (Steven MacGregor)
      (Anthony Politzi)
      Tyrantosawrus Rex (Chris Mason)
      SHW
      (Steven MacGregor)
      (Anthony Politzi)
      Octopush 2 (Chris Mason)
      ANNIHILATOR
      ROTROTB (Steven)
      SD IV (Steven)
      Bloody Tears 2 (Anthony)
      Psycho Cyan Evolved (Anthony)
      Hell Machine (David)
      (David)
      Orka Mk4 (Chris)
      Axe-o-lotl (Chris)
      CHALLENGE BELT
      Killotine Evo (Steven)
      SUNCUST (Anthony)
      Flaming Hell (David)
      Cyclone Force 2.5 (Chris)
      Whirligig 4.0 (Steven)
      Mr Slave 2 (Anthony)
      Flipping Hell (David)
      Obliteration (Chris)
      8 places left in the main comp!
        Save a place for me please!!! In the main war and all side events if possible.
        (Message edited by andrewj on October 07, 2005)
          Me:
          Tengu 7
          Black Panther Queen
          Kali
          Dante
          Achilles
          salamander III
          scaramanga II
          mortis (s4)
          Sith (fw)
          Tiny Tengu (lw)
          blizzard (mw)(dunno what your views on weight are here, im sure you can pull enough off if need be)
          red knight (shw) just deduct 5kg through having a slightly thinner chassis and soem drilling
          http://www.alexjholt.tkwww.alexjholt.tk as normal
            can you also save me two spots in the Annihilator Richard?
            btw, is entering the other-weight events optionally?
              Sorry to fudge up the seedings Richard, but I only enter things these days to make up numbers, and it looks like weve got enough people around to do that without my help.
                Martijn, yes, it is optional.
                Alex, do you think reducing Blizzards armour to 4mm aluminium boron carbide and some hole drilling would reduce the weight enough?
                Frank, does this mean youre not entering? Sorry to hear that.
                (Message edited by velociraptor on October 07, 2005)
                • #23
                  Able to save a space for a previous 3 times consecutive champ?
                  • #24
                    Ill be entering:
                    MDU 3
                    Rogue
                    Intensity
                    MOABIE
                    Infusion (new design)
                    The Ultimate Wedge (new design)
                    Sewer Snake (Real Robot)
                    Warrior SKF (Real Robot)
                    Ill have to work out my AW, FW, LW, MW tonight, but Ill be entering Gyrate Extreme in the SHWs.
                    Some stats up in the next post.
                    • #25
                      Mass Disctruction Ultimate 3
                      Motivation: Wheels
                      Speed: 12MPH (480MPH Tip Speed)
                      Weight: 100kg
                      Height: 250mm
                      Diameter: 800mm
                      Weapon: The robot itself is the weapon. It uses its drive and a custom made micro processor system similar to that used in a fellow translational spinner called Cyclone Bot to translate itself around the arena creating a €œVortex of Destruction€. Using 9 Hardox €œenlightened€ teeth, it tears its opponent to pieces when the teeth collide at a sub-sonic speed of 480MPH. Causing certain death to the opponent.
                      Drive: 3 x Briggs & Stratton Eteks running on 60v. The motors are protected with a current limiting circuit and a thermal protection system which will ensure the motors don€™t over heat. The drive system uses a unique variable drive system with load sensing technology which enables the robot to start rotating with a high gear ratio preset at 5:1 giving the motors high torque low speed. As the robot gains rpm, which is constantly monitored via wheel rpm sensors, the gearing then adjust to suit the load of the motors and gain further speed allowing the gear ratio to lower from 10:1 to as low as 1:1 at top speed. The gear ratio can also over drive thrown the ratio 1:2 giving the robot nearly double the original top speed and allowing far more energy, but this is only used when the opponent is at a distance where it can easily be disposed of. Otherwise, the drive is left at 1:1 maximum.
                      MDU 3 sports an advanced drive control system to that of Cyclone Bot as it uses motor and wheel sensors to travel and translate in the most efficient possible way, minimising energy lose. The drive will adjust ratio to suit condition if it is loaded and will change if need to translate at the full 14MPH (6MPH up on the last version since the robot size has decreased for faster movement, quicker spin up times and thicker armour). Spin up time is minimal and varies between 0.5sec spin up and 1sec when the system is suffering from battery voltage drop. At a mere 1/7th of its full RPM, this robot will be dangerous. 500rpm will have enough energy to throw robots out the road and allow it to continue it quest for domination. If people start ganging up on it (Everyone will, I know), the drive system will be locked down into 500rpm mode allowing the drive to have nearly maximum potential torque yields and it will force the opponents away till it can then safely power back up to full speed and deliver the force of the €œVortex of Destruction€. To ensure endurance during combat, everything has been shock mounted for maximum protection.
                      Batteries: 250 x 3600mAh NiCD cells producing 60v @ 18amps. The packs are protected by a system like the drive which give both current and temperature protection. The packs are re-enforced between the cells with Polypropylene cell holders and will prevent them from breaking during the impacts.
                      Armour: 4mm Hardox 500 with stainless steel welding built in a monocoque design with triangle shape and inner supportive bulkheads. 10mm Polycarbonate on the top to save weight due to the upgrade to Etek motors and higher voltage
                      Notes: Invertible. Soon to be your worst nightmare. All within your precious 100kg weight limit. Approche Avec prudence.
                      Mother of All Bricks Inevitably Evolved
                      Motivation: 4 Titanium wheels with urethane rubber and NIB magnets inside the rubber for extra traction on metal floors.
                      Speed: 15MPH
                      Weight: 100kg
                      Height: 220mm
                      Length: 650mm
                      Width: 620mm
                      Weapon: An active electric wedge, works both ways up and is primarily used to get under the opponent and allow the drive to show them the walls.
                      Drive: 2 x LEM200D motors producing around 52HP peak each when on there nominal 60v. The motors are current limited to 400amps, which limits the constant HP to 35HP combined. The motors will be run at 59.2 volts
                      Batteries: 16 x 3.7v 40000mAh Lithium Polymer cells producing 59.2 volts @ 40amps. The Lithium Polymer will give continous amperage of 5C(200amps) and peaks up to 10C (400amps)
                      Armour: 6mm Hardox 450 all over
                      Notes: Invertible
                      Rogue
                      Motivation: Wheeled
                      Speed: 18.84KMH (11.775MPH)
                      Weight: 91.39kg
                      Height: 248mm
                      Length: 523mm
                      Width: 1040mm
                      Ground Clearance: 10mm under disc teeth and increases to 20mm at the back.
                      Weapon: The weapon is a 24.61 kg, 580mm (From tooth tip to tooth tip) diameter flywheel mounted on a 20 degree angle. The flywheel is powered by a 6.8kg 125cc 5.3Kw (7.06HP) Husqvana chainsaw with modified Astroflight electric starter motor. The chainsaw has a peak RPM off 8500rpm and is geared 3.4:1 with a kevlar innerbound belt drive to produce a flywheel speed of 2500rpm. The chainsaw has a centrifugal clutch that prevents the flywheel from spinning at idle and prevents the chainsaw from stalling by cutting out at 500-600rpm. The weapon has a tip speed of 273.14Km/h while producing around 32Kjs of Kinetic Energy. The teeth are based on a shark tooth design where a inner concave to cut though metal much quicker and easier. The teeth are CNC machine blocks of Hardox 650 Wareplating to maintain a near perfect cutting edge.
                      Drive: The drive is a pair of S28-400 Magmotors coupled to a pair of 8:1 aluminium planetary gearbox which gives a final output speed of 500rpm at the drive shaft. The wheels are 200mm (8inch) Colson wheels with 3.25 mm Hardox 450 protection plates and 8mm thick Grade 5 Titanium/Vandium domes with tip spikes. The wheels are mounted on 40mm hollow, 5mm wall Stainless Steel shafts for maximum strength.
                      Batteries: 2 x 24v 3600mAh NiCD Battlepacks producing 24v @ 7200mAh supply (Enough for 10mins of solid driving, 8 mins of driving with several motor starts)
                      Monocoque (Chassis/Armour): The monocoque (chassis & armour combined) is a fully tig welded 8mm thick Grade 5 Titanium/Vandium with support braces and inner bulk heads for maximum strength and rigidness.
                      Electronics: Runs a RoboWars.org BMC speed controller with Hitec Focus SS-3 75mhz PCM 3ch Radio and a 3-axis computer Gyro for maxium control and handling. Uses 150amp rated Anderson power pole connectors and locking pins. Electronics are shock mounted and mounting in a floating style encased in HD (High Density) foam.
                      Notes: Can selfright via off balance weight distribution whe upside down and is added by the contact of the flywheel on the floor.
                      Gyrate Extreme (SHW)
                      Motivation: 4 x Omni wheels
                      Speed: 10MPH
                      Weight: 155kg
                      Height: 320mm
                      Length: 500mm
                      Width: 1500mm
                      Weapon: The weapon is the focus on the robots upgrade. The 45kg spinner bar/hoop combo is powered by two Honda CR125 Motorbike motors. The CR125 motor produces 42.3BHP @ 11500rpm, and only weights 14.8kg each. The motors have a pair of electric starts mounted on them. The weapon rotates at a crazy 4500rpm, via a variable belt drive that changes ratios from 10:1 through to the final 2.5:1 ratio. The variable belt drive works by the expansion of one pullie (Motor end) and the contraction of the other (Weapon end) This is done via torque springs mounted on the adjustable pullies and forces them to change size when the load changes. Commonly found on 6WD amphibious ATV€™s.
                      Drive: 4 x LEM 130€™s on 24v geared 10:1
                      Batteries:
                      Armour: Can you say 15mm Poly-Propylene?
                      Notes: The weapon is devastating. The power is phenomenal. The noise is incredible! The bot is not invertible€¦ Flip and gone€¦€¦ But you have got to get close to it to flip it!
                      Warrior SKF: http://www.buildersdb.com/botpics/2396.jpghttp://www.buildersdb.com/botpics/2396.jpg Team Whyachis 1000rpm Ring Spinner that powers the front flipper. Was able to launch Cyclonebot over 8ft into the air! The spinning rim is 2inch thick Cromemoly 4130 Steel!
                      Sewer Snake: http://www.buildersdb.com/botpics/374.jpghttp://www.buildersdb.com/botpics/374.jpg Ram bot with a front lifting wedge. Currently ranked #1 in the US and has beaten countless amounts of spinners, despite having exposed wheels.
                      • #26
                        Aaron, Gyrate is a bit overweight like Alexs Blizzard, so shall I reduce the armour by 1 or 2mm?
                        There are currently:
                        *5 places left in main comp
                        *1 place left in middleweight, lightweight and featherweight (that is, if AJ meant those when he said he wanted a place in all side events)
                        *2 places left in antweight and superheavyweight (again, assuming AJs entering these)
                        *3 people/6 robots needed to enter the Annihilator
                        (Message edited by velociraptor on October 08, 2005)
                        • #27
                          Yep, save me places in the otherweights too please. Im going to be away this weekend but I can start work on my bots by Monday if thats OK.
                          • #28
                            Thats fine
                            Also Ill have archangel and baldur in the annihalator
                            • #29
                              Sorry Alex, but the robots you enter in the Annihilator have to be ones youve entered in the main comp.
                              • #30
                                Stats for Ram-Raider
                                Weight: 18 kilos
                                Body Shape: A bit like 101 without the tracks.
                                Speed: 23mph
                                TC:0
                                GC: 1mm all round
                                Wheels: 2 sets of Banks. In other words, its a shuffler.
                                Armour: 3mm aluminium on top and bottom, nothing on the sides.
                                Power: I dont know what a suitable power source for a featherweight would be. Could someone offer any helpful suggestions?
                                Colour: Green on one side, Purple on the other.
                                Weapons: A horizontal saw blade powered by its own motor (again, advise would be nice) is the active weapon, but its own brute force provides the main weapon.
                                Srimech: The robot can run inverted. You could TRY to side strand it, but it has ears to prevent this.
                                Strengths:Brute power.
                                Weaknessess: Weakish armour.
