Velociraptors Fanfic Tournament - Series 7!
The real Robot is Overkill.
ORKA MK4
Weight: 100 kilos
Body Shape: Behemoth
Speed: Some 15mph
TC: 0
GC: 2mm, 0mm at front.
Wheels; 6 inner
Armour; 7mm titanium
Power; 3x 12v batteries, powered by a couple of Magmotors
Colour; Black with white patches
Weapons; A Behemoth like bucket scoop, made from titanium, and quite capable of lifting 300 kilos. It has a claw like device to grab an oppodent, like the claw on Mantis. The scoop is pnumatically powered, and has about 45 odd flips.
Srimech: It has a dorsal fin on top used for self-righting
Inspiration; Ive always liked Orcas. Adding the K made it sound more dangerous.
Strengths; Weapon
Weaknessess: Hard to turn
BIO
Every big team needs some big star to bring in the crowds. My big name is Orka MK4, representing Team Dinowarrior in all its glory.
No one is faster, smarter or more agile than Orka Mk4. When charging, other robots need to get out of his way. He can flip just about ANYTHING that doesnt take the warning, or simply grab hold of them. Hes ready for battle! Are you?
DIE-CERATOPS RE-INVERTUS
Weight; 100 kilos
Body Shape: Wheely Big Cheese
Speed; 15mph
TC; 0
GC; 0mm at front, 3mm at sides and back.
Wheels; 2 inner, sticking out only slightly,
Armour; 8mm titanium
Colour; Green, with Killer Carrot style wrinkles, mouth and eyes. One of the eyes has a plaster over it, the other is a black eye. A few bandages are painted on this time.
Weapons: A huge Wheely Big Cheese style flipper, capable of flipping a tonne or so.
Srimech; As the name suggests, the robot runs inverted. Bars prevent side strandings, and the back is rounded, so stranding THAT way is outta the question. The flipper works upside down.
Inspiration; Ive always liked Dinosaurs. This is a pun of Triceratops. The Invertus part is pretty obvious.
Strengths; The ability to work upside down and still be able to use its weapon, now easier to control.
Weaknessess: Tengu VI
BIO
Orkas cute-on-one-side-pure-hell-on-tuther friend, Die-Ceratops is equally as powerful and as nippy as his buddy. In the arena, he can get to oppodents/victims in record time. Then, once his flipper is underneath them, they can kiss the ground good-bye. Of course, hes teamed with me, and I can be rather protective over him...
CYCLONE FORCE 2.5
Weight; 100 kilos
Body Shape; Storm 2
Speed; 25mph
TC; 0
GC; Side is 0mm due to skirts. Back is 2mm. See set-ups for front GC
Wheels; 6 inner
Armour; 7mm Titanium.
Power; Similar stuff to what Storm 2 uses.
Colour; A blue-ish grey tone all over.
Weapons; The robot has 5 set-ups, 2 brand new...
SET UP 1...A lifter device, similar to Storm 2. In theory, it can lift 190 kilos. The front makes a wedge and results in a 0mm GC. However, the wedge is useless upside down.
SET-UP 2...A pair of Kan Opener style claws, with about 4 tonnes of pressure at the tip. Front GC for this and Set-up 3 is 1mm.
SET-UP 3...A Disc-O-Inferno style disc, reaching speeds of up to 3000rpm and with similar damage capability to this dangerous bot (I mean, look what it did to Panic Attack).
SET-UP 4...Two 30cm long spikes, which, combined with the speed of the robot, can easily penetrate weaker armours (Id say anything 4mm thick or less, minus Steel, is in a bit of trouble).
SET-UP 5...The most risky approach, A simple bucket scoop, like X-Terminator. The scoop is static, but can get underneath virtually zero ground clearance. Its front is 0mm.
Srimech; The robot runs inverted, the sides are protected by the skirts and back stranding is impossible. Set-ups 2, 3 and 4 work upside down.
Inspiration; The original Cyclone was named because it is the name of a storm and it sounds threatening. The force came later, after it became a pusher.
Strengths;Raw power
Weaknessess;Lack of control, Set-ups 1 and 5 do not work upside-down.
BIO
When Cyclone Force 2.5 is in the game, every other piece of metal is scrap! Cyclone can travel across the arena with great speed AND power. His interchangable weapon system means NO ONE is safe. Thank goodness hes harmless when turned off.
LEPROSY INFECTION
Weight; 100 kilos
Body Shape; Tetanus Booster
Speed; 18mph
TC; 0
GC; 2mm
Wheels; 4 inner, top sticking out. Wheel flaps are situated either side of the wheel to protect them.
Colour; A disgusting shade of lime green.
Weapons; A very large, very dangerous vertical drum, capable of reaching speeds of 4000rpm. The teeth on the drum are curved upwards so they can flip as well as damage and very sharp at the tip. There is a reason for this...
Srimech; The robot is invertable. Bars along the side and back prevent stranding. The wheel flaps, both on top and bottom, are set so the robot can still run inverted without getting stranded. Once upside down, the teeth of the drum gouge out robot parts.
Inspiration; Named after the disease which causes the skin to flake and fingers and toes to drop off...namely because the robot does something similar. The basic idea came from an episode of The Simpsons.
Strengths; Drum, control is pretty good
Weaknessess; Wheels may be vulnerable to axes
BIO
When youve got sharp teeth, sickeningly bright green paint and a name of a skin disease, battle invitations are pretty remote. So, hes loving life in the Robot Wars arena where he can make others sick. Leprosy Infections drum is killer! And when hes upside down, those teeth start gouging out his prey. Grrr...
MEGA MASHER 2
Weight: 100 kilos
Body Shape: Minion
Speed: 12mph
TC: 0
GC; 0 at front, 1mm at sides due to skirts.
Wheels; 4 inner.
Armour: A nice 3mm of steel
Power: Similar stuff to what Tornado uses.
Colour: Red and yellow.
Weapons; The front is a wedge, and the back has a nasty vertical disc, powered by its own motor and spinning at 2000 rpm. It can probably flip as well as damage. A side Minion style bar comes out from the side.
Srimech: The aforementioned bar rights the robot, even though it can run inverted.
Inspiration; This is probably the only robot I have where I have had no inspiration. It just came as a good name.
Strengths: Power, weaponary
Weaknessess: A little bulky, not as heavy as the body would suggest.
BIO
Mega Masher is still hell bent on robot destruction. Whether you think of him as the baddest, most brutal robot ever or just a power crazed crazy thing - just dont tell him when his disc is spinning at full throttle! His wedge is also dangerous; being one of the lowest out there. Dont trust this robot to lose as far as you can throw him! Even better, dont try to throw him at all; hes based around Battlebot champion Minion, and way too bulky for flipping.
AXE-O-LOTL
Weight: 100 kilos
Body Shape: Comengetorix
Speed: 20mph
TC: 0
GC: 2mm
Wheels: 4 inner
Armour: Mainly aluminium (5mm) with 3mm Titanium top plates.
Power: Same stuff as Storm 2 and Cyclone Force uses.
Colour: Has interchangable panels. One set is pure black, the other pure white with pink tinges.
Weapons: A very nasty axe, with the power of Dominator 2. The head is diamond tipped, and the whole weapon is VERY persistant. It can fire about 40 times in one fight.
Srimech: The axe rights the robot. The robots body is designed so it cant be side stranded.
Inspiration: My favourite amphibian, the axolotl.
Strengths: Powerful weaponary
Weaknessess: Questionable armour.
BIO
Axe-O-Lotl likes a bit of Mexican chilli powder with his lubricating oil. After a break in Mexico, Axe-O-Lotl has returned to join the mightiest of the mighty on Team Dinowarrior. His powerful/persistant axe is brutal, and he has just as much power as Cyclone Force.
OBLITERATION
Weight: 100 kilos
Body Shape: Revolutionist
Speed: 5mph
TC: 0
GC: 5mm all the way round. It has to be.
Wheels: 8 inner (4 on top, 4 below)
Armour: 7mm titanium
Power: It drives on 3x 12v batteries plus a couple of Magmotors. For the weaponary, the power matches Phrizbee.
Colour: Dark blue with tinges of black and brown.
Weapons: This robot is a full body spinner. The teeth are increibally sharp. It spins at about 500 rpm, and does damage similar to Phrizbee.
Srimech: Unusual for a FBS, this robot runs inverted.
Inspiration: It sounded cool. It also sounds like a ride at an amusment park, if you ask me.
Strengths: Body! Need I say more?
Weaknessess: Rather slow, First timer
BIO
Obliteration has the disposition of a train wreck many times over. Though he prefers to take his time around the arena, his super powerful spinning body delivers a nasty blow. Obliteration is a first stringer, and considers himself A closer - And he doesnt like having his photo taken for some reason! Watch out for this guy - hes no sweet pleasent ride let me tell you!
ANNIHILATOR: Orka MK4 and Axe-O-Lotl
CHALLENGE BELT: Cyclone Force 2.5
HOUSE ROBOT REBELLION: Obliteration
ANTWEIGHT: Tyr-Ant-O-Saw-Rus Rex
FEATHERWEIGHT: Ram Raider
LIGHTWEIGHT: Little Big Bot
MIDDLEWEIGHT: Tom
SUPERHEAVYWEIGHT: Octo-push 2
Stats for these hopefully this weekend.
ORKA MK4
Weight: 100 kilos
Speed: Some 15mph
TC: 0
Wheels; 6 inner
Strengths; Weapon
BIO
Weight; 100 kilos
Speed; 15mph
TC; 0
BIO
CYCLONE FORCE 2.5
Weight; 100 kilos
Body Shape; Storm 2
Speed; 25mph
TC; 0
Wheels; 6 inner
Strengths;Raw power
BIO
LEPROSY INFECTION
Weight; 100 kilos
Speed; 18mph
TC; 0
GC; 2mm
BIO
MEGA MASHER 2
Weight: 100 kilos
Body Shape: Minion
Speed: 12mph
TC: 0
Wheels; 4 inner.
BIO
AXE-O-LOTL
Weight: 100 kilos
Speed: 20mph
TC: 0
GC: 2mm
Wheels: 4 inner
BIO
OBLITERATION
Weight: 100 kilos
Speed: 5mph
TC: 0
BIO
MIDDLEWEIGHT: Tom
