Velociraptor's Fanfic Tournament - Series 7!
  • #76
    Velociraptors Fanfic Tournament - Series 7!
    Mr Nasty will be fine thanks.
    • #77
      6 done, 2 to go
      this bot will also enter the Challenge Belt
      Name - Sheer Heart Attack
      Shape - Invertible tracked box, only the main-body between the tracks is shorter then the tracks (as can be seen on the picture), build in such a way that the tracks are in contact with the ground no matter what (like 101), only with two titanium bars at the end of both tracks to protect them from destructive spinners
      Weight - 110 Kilogram
      Speed - 24 km/h (15 mph)
      Dimensions - 90*100*25 cm
      Ground Clearance - Zero underneath the tracks, but with an overhang
      Power -2x LEM130s at 48v
      Movement - Two sturdy titanium tracks, with rubber strips attached to them for traction
      Turning Circle - Zero
      Weaponry - A 22 kilogram titanium spinning drum at the front of my machine equipped with 10 hardox teeth, powered by a LEM 130 and spinning around at 5000 RPM, which produces nearly 40 kJ.
      Armour - 6 mm titanium all around (including the tracks themselves)
      Srimech - It€™s invertible
      Strenghts - Devestating against most wedges, nice traction
      Weakness - Exposed (but quite sturdy) tracks might be a weakness
      Notes- I designed this robot to be a robot which gains it€™s advantage by driving OVER an opponent, a bit like Barberous. The exposed tracks are the ultimate way to keep in contact with the floor no matter what kind of ramp I drive up, so that if a good rambot or whatever gets underneath me in a threatening way, I can simply go in full reverse and escape. The drum, ofcourse, is a perfect way to hurt an opponent while he€™s underneath you.
      Here€™s a picture: http://jupiter.walagata.com/w/madbull/Tracks2.gifhttp://jupiter.walagata.com/w/madbull/Tracks2.gif
      • #78
        Stats for No Stairway to Heaven changed:
        Weight: 150 grams.
        Speed: 40cm a second
        Armor: 1mm HDPE on the sides and rear, 1mm kevlar on top and bottom, 1mm titanium on front.
        Weapon: 1 ounce drum spinning at 3000 RPM, producing 12kjs.
        Power: Run on 4 JP Supertech Naro Maxes on 6v. The weapon is powered by a stinger motor on 6v.
        Notes: There is a plow so large it surronds the sides and rear. It does not cover the front, as not to get in the way of the plow.
        GC: 0 at sides and rear thanks to plow. 5mm at front.
        Turning circle: 0.
        Strengths: Good all arounder, no real weaknesses.
        Weakneses: Dosent excel at anything.
        • #79
          My 7th entry will be the realie Fluffy, my 8th entry will be:
          Name - Liar
          Shape - A bit like a non-invertible Wheely Big Cheese, it has a fairly wide wheel-to-wheel base at the back, while the front is a much smaller (and pretty long) wedge, the front of the wedge has to €œside wedges€ as can be seen on the pic
          Weight - 100 Kilogram
          Speed - 29 km/h (18mph)
          Dimensions - 120x60x30 cm
          Ground Clearance - 0 mm at the front and underneath €œside-wedges€, 7 mm anywhere else
          Power - 2 S28-400 Magmotors at 24 volt
          Movement - 2 inner wheels, 15 cm in diameter
          Weaponry - The wedge contains a 1000 psi titanium rear-hinged flipper (basically the red parts of the picture), powered by two pneumatic rams. It should be able to give a 100 kg robot a height of some meters. As can be seen in the picture, the flipper has two €œside-wedges€. I have added them since I saw that flippers tend to be quite weak when attacked at the back. When Liar is attacked at the back, he simply does the same as Stinger does when he goes into flail mode. By doing so, the side wedge will ram into the opponent and shove underneath it. That way I can use my flipper and get it on his back. Although this flip will not be as powerful as a frontal flip, it will be a flip nonetheless, and it will help me get rid of any threats that approach me from the back.
          Armour - 8 mm titanium all around
          Srimech - That flipper
          Strenghts - Powerful and maneuverable flipper
          Weakness - Won€™t be pushing much, won€™t be damaging much either
          Here€™s a picture: http://jupiter.walagata.com/w/madbull/flip.gifhttp://jupiter.walagata.com/w/madbull/flip.gif
          • #80
            My real robot will be Suicidal Tendencies (series 5)
            AntyB (aw)
            Someones watching over me (shw)
            Disco tech 2 (challange belt)
            Take Me Out (HRR)
            • #81
              Thanks, guys!
              Anyone else entering?
              • #82
                8 robots you say:
                Tornado (series 7)
                Typhoon 2 (series 7)
                Judge Shread 3.5 (series 7)
                Biohazard (Season 5)
                SOW (Season 3 verison [classed as a HW])
                Bolt From The Blue (Series 4)
                Tiberious 3 (series 7)
                Black Hole (Extreme 2: Euro Championship)
                Reserve bot - Iron Awe 3 (The flipper)
                If you have any problems, please address them to:
                Lord Lucan
                Somewhere in Brazil
                Earth
                (BTW, rule 7 which states 07. Basic Robot Wars rules on what is and isnt allowed apply to anything I havent mentioned. the basic Robot Wars rules only allow 36 volts to be used max)
                Dave
                (Message edited by MrDaveS on October 19, 2005)
                • #83
                  Thanks, Dave! Ill take Iron Awe 3 rather than Black Hole, as Ive never seen the Euro Championship but Ive found details on IA3 on the Net.
                  Two places left! Is it possible for you to enter after all, Frank and Matty? Theres no pressure, but it would be a help.
                  Will it be possible to run Wind Chasers flipper on less power, then, Martyn?
                  • #84
                    Actually Dave, could you replace Son of Whyachi as well? I think its technically a shuffler (correct me if Im wrong) and probably weighed more than 110kg (again, correct me if Im wrong), which would make it overweight for this tournament.
                    (Message edited by velociraptor on October 20, 2005)
                    • #85
                      erm... *sigh* I suppose so... maybe I will get another shot at winging after all.
                      • #86
                        Can I have Ansgar 3 from the world championship?
                        BTW, happy 700th post Richard.
                        • #87
                          Thanks, Matty! And sorry, Dave, but Ansgars too heavy as well.
                          • #88
                            Dave you are so hypocrytical, when other people want to enter both SoW and Ansgar 3 you say there over wieght now you want to do it. Hummmm suspesious
                            • #89
                              FW done.
                              Weight: 12kg
                              Color: Scarlet, duh.
                              Power: 2 Dustin Motors on 24v, High Torque. 2 NiCads supply it.
                              Speed: 10mph
                              Armor: 5mm titanium.
                              Weapon: 2 sledgehammers, one on each side.
                              Shape: Like a standard thwack, but with casters to prevent unbalance on the top and bottom.
                              Notes: A hinged wedge on the front and back.
                              Strengths: Double-duty thwack for destruction or pusher for pitting or ramming into hazards, good at whatever it does, decent armor.
                              Weaknesses: Control might be a tad off.
                              This alright?
                              • #90
                                Wind Chasers flipper will now run at 36volts instead of 60
