Tri-Tainium will take part, as hes yet to win anything
TRI-TAINIUM
€ WEIGHT: 100kg
€ ARMOUR: 4mm Hardox for the back/scoop. The top and bottom panels are 5mm Titanium and the sloped sides are 6mm Hardox to sheild the wheels.
€ SHAPE: Low invertible box with a front scoop (the scoop has a slight dip in it to help get under other robots better) and sloped sides.
€ MOTORS: 2 x LEM 130€™s at 36V = 18HP
€ LOCOMOTION: 4 Vulkanised Wheels.
€ DIMENSIONS: (L) 60CM (H) 20CM (W) 60CM
€ COLOUR: Unpainted, with the exception of the name on top written in black paint.
€ WEAPONRY: The weaponry consists of 3 x 9kg discs, made out of 1cm of Titanium with 3 Hardox bludgening teeth. The discs are set on the same axle, and amounted deep into the scoop, with the teeth just reaching towards the lip of the scoop, so the uppercut movement of the discs can attack base-panels and the like. The discs are powered by 2 x LEM130s at 36V. Set on a ratio of 1.5:1, it gives off 3600rpm. The discs, combined together make 27kg, so the force given out is 165kj per hit! Large amounts of Rubber amounted behind the scoop stops the risk of self-destruction.
€ SPEED: 18mph
€ GROUND CLEARANCE: 0MM-1CM. At the front, it is completely 0mm. On the sides/rear, its 1cm.
€ STRENGTH: Weaponry.
€ WEAKNESS: Completely new design.
But Joeys right - start a new thread for this, not invade that of a former forum member.
My latest world beater:
Shape: Wedge
Colour: Yellow
Drive: 2 Triangler Wheels, they do work using the massive mystery motors which are a mystery as to know what they are you would have to sign the offical secrets act, giving 20hp and 100nm of torque from just 12 volts, again these motors are secret
Speed: Once it gets going it is like a train, getting up-to 60 mph if the arena was large enough
Ground clearance: Variable, pending on where the wheels are on the cycle.
Armour: Some rather tasty looking super-strength cheese, with a steel chassis and inner box where the cheese sits on top.
Weapons: The wedge
Srimech: Nope
Extra notes: Makes a mess of arenas in more ways then one
