Summer of Robots tournament.
    Ill enter Smash-Up At The Bar... Stats Up Soon.
      Anyone else?
        flippy likes flirting with the house bots
          Firestorm doesnt flirt with house robots. It just flips them
            This is an incomplete thread, so I will take control of it.
              Ahem, I am Mark Elam, and welcome to the Extremely Crummy Tournament.
              I need 8 of the worst vapourbots of all time. These bots must not have won any matches.
                ...is there a reason you couldnt just start a new thread?
                • #23
                  Tri-Tainium will take part, as hes yet to win anything
                  TRI-TAINIUM
                  € WEIGHT: 100kg
                  € ARMOUR: 4mm Hardox for the back/scoop. The top and bottom panels are 5mm Titanium and the sloped sides are 6mm Hardox to sheild the wheels.
                  € SHAPE: Low invertible box with a front scoop (the scoop has a slight dip in it to help get under other robots better) and sloped sides.
                  € MOTORS: 2 x LEM 130€™s at 36V = 18HP
                  € LOCOMOTION: 4 Vulkanised Wheels.
                  € DIMENSIONS: (L) 60CM (H) 20CM (W) 60CM
                  € COLOUR: Unpainted, with the exception of the name on top written in black paint.
                  € WEAPONRY: The weaponry consists of 3 x 9kg discs, made out of 1cm of Titanium with 3 Hardox bludgening teeth. The discs are set on the same axle, and amounted deep into the scoop, with the teeth just reaching towards the lip of the scoop, so the uppercut movement of the discs can attack base-panels and the like. The discs are powered by 2 x LEM130s at 36V. Set on a ratio of 1.5:1, it gives off 3600rpm. The discs, combined together make 27kg, so the force given out is 165kj per hit! Large amounts of Rubber amounted behind the scoop stops the risk of self-destruction.
                  € SPEED: 18mph
                  € GROUND CLEARANCE: 0MM-1CM. At the front, it is completely 0mm. On the sides/rear, its 1cm.
                  € STRENGTH: Weaponry.
                  € WEAKNESS: Completely new design.
                  But Joeys right - start a new thread for this, not invade that of a former forum member.
                  • #24
                    Not entering.
                    • #25
                      Fine, Kody.
                      Besides, your bots HAVE won matches.
                      • #26
                        Doesnt mean Ill enter.
                        • #27
                          I know.
                          • #28
                            My latest world beater:
                            Shape: Wedge
                            Colour: Yellow
                            Drive: 2 Triangler Wheels, they do work using the massive mystery motors which are a mystery as to know what they are you would have to sign the offical secrets act, giving 20hp and 100nm of torque from just 12 volts, again these motors are secret
                            Speed: Once it gets going it is like a train, getting up-to 60 mph if the arena was large enough
                            Ground clearance: Variable, pending on where the wheels are on the cycle.
                            Armour: Some rather tasty looking super-strength cheese, with a steel chassis and inner box where the cheese sits on top.
                            Weapons: The wedge
                            Srimech: Nope
                            Extra notes: Makes a mess of arenas in more ways then one
                            • #29
                              What, no pie?
                              • #30
                                1. Tri-Tanium
                                2. The Lump
                                3.
                                4.
                                5.
                                6.
                                7.
                                8.
                                Six more spots available.
