Mass-100kg
Weapons-front hinged flipper running at 175psi
Dimensions-95cm length/80cm width/40cm high
Shape-low wedge shape/sloped rear with skirts on the side
Wheels-Four inner wheels
Top Speed-22mph
Armour-6mm titanium all round
Motors-2x LEM130s at 36v
Power-4 x 48v NiCD 3600Mah Packs
Ground Clearance-0mm around the whole body.
Strenghs-Nippy around the arena, dependable armour, good weapon, can get under anything.
Weakness-Flipper cant get robots OOTA all the time (it can some times)
Enterprise
Dimensions-95cm length, 80cm width, 40cm height.
Weight-100kg
Shape-low wedge/sloped rear with Biohazard like side and rear skirts
Wheels-4 inner wheels
Speed: 19 mph
Weapon:A rear-hinged flipper. There is a strip on the bottom of the flipper, allowing the flipper to get under bots with skirts. The flipper is 1000psi. There is the option of removing the strip and putting a small titanium plate that extends the flipper out 15cm. It could be used against dangerous spinners. Spikes at the back to prevent the robot from flipping itself over.
Motors-2 LEM-COs running at 36v
Power-4 x 36v 3600mAh NiCD packs
Armour-7mm titanium all around
Ground Clearance-0mm front, 0mm around the sides/back with skirts.
Turning Circle-0m
Strenghts-Powerful flipper, nippy around the arena.
Weakness-Flirts with Matilda.
Firefly
Mass-100kg
Weapons-front hinged flipper running at 1000psi, with a back attachment so you can flip robots from the back. Need any pics, just ask.
Dimensions-90cm length/80cm width/35cm high
Top Speed-20mph
Armour-7mm titanium all round
Ground Clearance-1mm around the whole body.
Strenghs-Nippy around the arena, dependable armour, fast weapon, can get under anything.
Weakness-Flipper cant get robots OOTA all the time, but it can send a robot far.
I counted 10 new HWs from when I last entered [revamp for clusters may happen, espically for 4 Swords]
http://farr.proboards21.com/index.cgi?board=Hitmenhttp://farr.proboards21.com/index.cgi?board=Hitmen
Vlad 2
Deathstar [Hey, its cool]
Towering Inferno [Again, coolness]
Mechavore
Omega 13
Hexadecimator
Everyone has at least 1 seed, a maximum of 4. However many seeds you have, youve been given an extra number of automatic places to make your total up to 4, however all automatic qualifiers have been drawn against the low seed of each heat for their first round. The draw template has been made and the seed s have been sorted and out in, however for now I give you the other 160 robots and their qualifying draws.
The other thing to bear in mind is that the nature of the tournament means you are gonna draaw yourself and in soem cases there are as many as 3 robots by one person in a melee. Im not gonna sort it, so dont complain. Hey, it means youre guaranteed at least one place.
Anyway, heres the draw.
Drilla Killa Renaissance v Kronic v Hexadecimator v Archangel Of The Abyss
Thermidor 2 v Heart Of Fire v Hell Brand v YACATR
Snakebite 4 v Plunderbird v No Not Steven Whatsisname v Tornado
Cyclone Force 2.5 v Twister (S7) v Metal Sonic Spin Dash v Natural Selection
All Apologies v Typhoon 2 v Chameleon v The Botles Reunited
Judo Chop v Jackson Wallop v Mantis v Agro 3.5
Flank Attack 2: DT v Shotgun Slapper v Battle Raptor 4 v The Raven
Tails v Slam Job v Drilla Killa 7 v Artemis
Atomic v Odysseus 2 v Blizzard v Firefly
Nightmare v Going Crunch v Corkscrew v Apply Some Pressure
M.O.R.D. 2 v The Matador v Slammer 5 v Obliteration 2
Mauler v A Vapourbot Named Frank v SYNDOS v Hector
Behemoth v Enterprise v Ruf Ruf Dougal v 4 Swords
Thor v Tenderizer€™s Revenge 2 v Scaramanga 2 v Banshee
Whirligig 4.0 v Psycho Cyan Evolved v Boulder Dash v Vlad 2
Sorrow v Brian Boltano v Tammy the 2nd v Robotnik Twins
Slaying Mantis F v Cacodemon v Gemini v Liar
Mace v Mega Masher 2 v Shovearound 2 v Chaos 2
Megalodon Maneater v Quake v Beta v Pullverizer
Street Magician v 360 v Dope On A Rope v Axe-O-Lotl
Death and Taxes v Sheer Heart Attack v Pussycat v Nodachi
Killer Carrot 2 v You Only Live Once v Scorpion Bite v Chaos
Sonic Boom v Psyclonic v Aquarius v The Big Push
Drillzilla v Daisy Chopper v Diotoir v Hurricane Hugo
Ringwraith v Judge Shred 3 v Big Nipper v Manta
Clawed Hopper v Baldur Gamma v Cyberdemon v Killeidascope
Love Bite V2.0 v Novastorm 2 v The Holy Hand Grenade v Split Decision
Stalker 2 v Malaria v Jack Kennedy v Toby The T-Ram Engine
Killotine: Evo v Leprosy Infection v Clawdius Decimus Murderous v Tough As Nails
Seigmund & Seiglinde v Darkestar v Vampire Killer v Salamander 3
Turbulence v Terror Gear 3 v Raging Knightmare v Sengakanzen
Omega 13 v GBH2 v Double Killa 2 v Kali
The Windmill v Squishiest v Bulldog Breed v Crushtacean
Die-Ceratops Re-Invertus v Mega Hurts L.T. v Axe To Fall v The Last Traction Hero Returns
Gravedigger v Death Adder 3 v Allanon v Dante
The Towering Inferno v Jim Struts v Bloody Tears 2 v Mechavore
Doc Ock QP v Fat Boy Tin v Revenge of the Revenge of the Bludgeonator v SUNCUST
Flick of the Wrist v Dr. Evil v Deathstar v Twister (S5)
Mario Brother€™s v SOR 1.0 v Biohazard v GigaByte 1.5
Mr. Slave 2 v Beavis and Bot-Head v Drum Roll 2 v The Doomsday Project
Tactics and Preictions As Usual Very Much Appreciated
Ill post tactics later, but, out of interest, No, Not Steven Whatsisname had a name change after I entered. If you want to, you can now call it Y4. Its exactly the same, only with a different name.
Oh, f*** Ive f***ed up. Ive just put both you and Chris C down as jsut Chris. You seem to have no seeds but 2 auto places. He seems to have 2 seeds and no auto-laces. Dargh...
