The Fowler Fic War 3.1
  • #46
    which real robots have been taken and how many robots can I enter?
    • #47
      Is reading just a few posts up such a grueling task?
      • #48
        I guess not.
        • #49
          Wolf
          Mass-100kg
          Weapons-front hinged flipper running at 175psi
          Dimensions-95cm length/80cm width/40cm high
          Shape-low wedge shape/sloped rear with skirts on the side
          Wheels-Four inner wheels
          Top Speed-22mph
          Armour-6mm titanium all round
          Motors-2x LEM130s at 36v
          Power-4 x 48v NiCD 3600Mah Packs
          Ground Clearance-0mm around the whole body.
          Strenghs-Nippy around the arena, dependable armour, good weapon, can get under anything.
          Weakness-Flipper cant get robots OOTA all the time (it can some times)
          Enterprise
          Dimensions-95cm length, 80cm width, 40cm height.
          Weight-100kg
          Shape-low wedge/sloped rear with Biohazard like side and rear skirts
          Wheels-4 inner wheels
          Speed: 19 mph
          Weapon:A rear-hinged flipper. There is a strip on the bottom of the flipper, allowing the flipper to get under bots with skirts. The flipper is 1000psi. There is the option of removing the strip and putting a small titanium plate that extends the flipper out 15cm. It could be used against dangerous spinners. Spikes at the back to prevent the robot from flipping itself over.
          Motors-2 LEM-COs running at 36v
          Power-4 x 36v 3600mAh NiCD packs
          Armour-7mm titanium all around
          Ground Clearance-0mm front, 0mm around the sides/back with skirts.
          Turning Circle-0m
          Strenghts-Powerful flipper, nippy around the arena.
          Weakness-Flirts with Matilda.
          Firefly
          Mass-100kg
          Weapons-front hinged flipper running at 1000psi, with a back attachment so you can flip robots from the back. Need any pics, just ask.
          Dimensions-90cm length/80cm width/35cm high
          Top Speed-20mph
          Armour-7mm titanium all round
          Ground Clearance-1mm around the whole body.
          Strenghs-Nippy around the arena, dependable armour, fast weapon, can get under anything.
          Weakness-Flipper cant get robots OOTA all the time, but it can send a robot far.
          • #50
            I counted 10 new HWs from when I last entered [revamp for clusters may happen, espically for 4 Swords]
            http://farr.proboards21.com/index.cgi?board=Hitmenhttp://farr.proboards21.com/index.cgi?board=Hitmen
            Vlad 2
            Deathstar [Hey, its cool]
            Towering Inferno [Again, coolness]
            Mechavore
            Omega 13
            Hexadecimator
            • #51
              Hypnodisc, Gravedigger, Raging Knightmare, Judge Shred 3, M2, Atomic, and Bigger Brother
              • #52
                if I can enter any more robots then it will be ruf ruf dougal and killer carrot 2.
                • #53
                  Accidently entered one realie too many, so scrap Towering Inferno.
                  • #54
                    If I keep in Towering Inferno... add in Tims 2 new realies and put in Kevins...
                    I ahve 218... the exact number I need... this toruney can start!!!!!!
                    The draw and seedings will be up as soon as I can do them:P
                    • #55
                      Am trying to work out how I get to 208...
                      Just bear in mind though that this is my GCS year, so fights may ahve to lose priority over exams and coursework.
                      (Message edited by Matty Haka on January 31, 2006)
                      • #56
                        I did all the f***ing seeds and everything, and then my PC crashed, argh, I gotta do it again now! *is p*ssed off*
                        • #57
                          OK, heres how Ive done it.
                          Everyone has at least 1 seed, a maximum of 4. However many seeds you have, youve been given an extra number of automatic places to make your total up to 4, however all automatic qualifiers have been drawn against the low seed of each heat for their first round. The draw template has been made and the seed s have been sorted and out in, however for now I give you the other 160 robots and their qualifying draws.
                          The other thing to bear in mind is that the nature of the tournament means you are gonna draaw yourself and in soem cases there are as many as 3 robots by one person in a melee. Im not gonna sort it, so dont complain. Hey, it means youre guaranteed at least one place.
                          Anyway, heres the draw.
                          Drilla Killa Renaissance v Kronic v Hexadecimator v Archangel Of The Abyss
                          Thermidor 2 v Heart Of Fire v Hell Brand v YACATR
                          Snakebite 4 v Plunderbird v No Not Steven Whatsisname v Tornado
                          Cyclone Force 2.5 v Twister (S7) v Metal Sonic Spin Dash v Natural Selection
                          All Apologies v Typhoon 2 v Chameleon v The Botles Reunited
                          Judo Chop v Jackson Wallop v Mantis v Agro 3.5
                          Flank Attack 2: DT v Shotgun Slapper v Battle Raptor 4 v The Raven
                          Tails v Slam Job v Drilla Killa 7 v Artemis
                          Atomic v Odysseus 2 v Blizzard v Firefly
                          Nightmare v Going Crunch v Corkscrew v Apply Some Pressure
                          M.O.R.D. 2 v The Matador v Slammer 5 v Obliteration 2
                          Mauler v A Vapourbot Named Frank v SYNDOS v Hector
                          Behemoth v Enterprise v Ruf Ruf Dougal v 4 Swords
                          Thor v Tenderizer€™s Revenge 2 v Scaramanga 2 v Banshee
                          Whirligig 4.0 v Psycho Cyan Evolved v Boulder Dash v Vlad 2
                          Sorrow v Brian Boltano v Tammy the 2nd v Robotnik Twins
                          Slaying Mantis F v Cacodemon v Gemini v Liar
                          Mace v Mega Masher 2 v Shovearound 2 v Chaos 2
                          Megalodon Maneater v Quake v Beta v Pullverizer
                          Street Magician v 360 v Dope On A Rope v Axe-O-Lotl
                          Death and Taxes v Sheer Heart Attack v Pussycat v Nodachi
                          Killer Carrot 2 v You Only Live Once v Scorpion Bite v Chaos
                          Sonic Boom v Psyclonic v Aquarius v The Big Push
                          Drillzilla v Daisy Chopper v Diotoir v Hurricane Hugo
                          Ringwraith v Judge Shred 3 v Big Nipper v Manta
                          Clawed Hopper v Baldur Gamma v Cyberdemon v Killeidascope
                          Love Bite V2.0 v Novastorm 2 v The Holy Hand Grenade v Split Decision
                          Stalker 2 v Malaria v Jack Kennedy v Toby The T-Ram Engine
                          Killotine: Evo v Leprosy Infection v Clawdius Decimus Murderous v Tough As Nails
                          Seigmund & Seiglinde v Darkestar v Vampire Killer v Salamander 3
                          Turbulence v Terror Gear 3 v Raging Knightmare v Sengakanzen
                          Omega 13 v GBH2 v Double Killa 2 v Kali
                          The Windmill v Squishiest v Bulldog Breed v Crushtacean
                          Die-Ceratops Re-Invertus v Mega Hurts L.T. v Axe To Fall v The Last Traction Hero Returns
                          Gravedigger v Death Adder 3 v Allanon v Dante
                          The Towering Inferno v Jim Struts v Bloody Tears 2 v Mechavore
                          Doc Ock QP v Fat Boy Tin v Revenge of the Revenge of the Bludgeonator v SUNCUST
                          Flick of the Wrist v Dr. Evil v Deathstar v Twister (S5)
                          Mario Brother€™s v SOR 1.0 v Biohazard v GigaByte 1.5
                          Mr. Slave 2 v Beavis and Bot-Head v Drum Roll 2 v The Doomsday Project
                          Tactics and Preictions As Usual Very Much Appreciated
                          Muchos Luff3
                          Matt
                          xmxmx
                          • #58
                            So, I take it that my seed is Orka.
                            Ill post tactics later, but, out of interest, No, Not Steven Whatsisname had a name change after I entered. If you want to, you can now call it Y4. Its exactly the same, only with a different name.
                            • #59
                              Oh, f*** Ive f***ed up. Ive just put both you and Chris C down as jsut Chris. You seem to have no seeds but 2 auto places. He seems to have 2 seeds and no auto-laces. Dargh...
                              That mean I have 13 vapourboteers... ah shit...
                              • #60
                                Wheres my vapour. Also theres 2 of my robots in the same battle.
                                (Message edited by dogbot4000 on February 01, 2006)
