The Annihilators
    The Annihilators
    Unless Dave changed the stats, which I dont think he did, here I found them:
    http://farr.proboards21.com/index.cgi?board=TeamSolarizedStats&action=display& num=1101676870http://farr.proboards21.com/index.cg...ion=display&nu m=1101676870
      The Annihilators
      Nothing has changed with Seggy 3 except its name, which means the basic stats for it are about 18 months old. Old school, I will replace it, but what is the point?
        The Annihilators
        So its time for the draw
        Mechavore V Beta V Storm 2
        Spawn again V automatic schmuck V disconstructor
        Hurricane Hugo V Tails V typhoon 2
        Aka IDIOT V Tenderizers Revenge 2 V Blizzard
        Wedge Devolution V MORD2 V Steggy
        Shove around 2 V X Terminator V Sorrow
        tactics?, predictions?, pie?
          The Annihilators
          I want pie
          and you spelt seggy wrong
            The Annihilators
            Go for tails. Hopefully I can tear him up before he tries to pit me. AFter that, till be a spinner vs spinner match, and I most likley have the stonger spinner. So hopefully it can rip up Typhoon before typhoon rips me up.
            Dave and I are teaming up on this. Once hes broken Shmucks weapon, ill flip him, and then pit him. Then after that, ill try to get Disconstructer OOTA.
            Being unable to find Stats of sorrow, and im not sure what Series 7 X-Terminator is, just avoid their weapons and pit them both.
              The Annihilators
              TR2 will run straight into Aka Idiot, try to stop his spinner and shove him down the pit. If I fail, I will go for Blizzard, shove, lift and pit him, then try Aka Idiot.
              MORD2 will use its scoop to shove Wedge Devolution around, and eventually pit him, then be aggressive to Seggy, using my drum and scoop.
              X Terminator will try to hit Sorrow on the side and knock him around - if he causes damage, I will focus on Shovearound 2.
                The Annihilators
                The difference between Daves jokes and mine, is at least I use something for material thats actually there :P
                • #23
                  The Annihilators
                  MECHAVORE: Stars and stripes forever! Here, stick to Betas sides and simply see if I can rip into the innards. Failing that, shove around with rear end and Pit. Repeat for Storm.
                  TAILS: go straight for Typhoon first n flip. Then ram the inverted RW champ into Hugo to try and stop the spinning or knock it off-balance. Once static, dash in with the blade and rip the weak armouring to pieces
                  WEDGE DEVOLUTION Keep to MORDs sides, penetrate the hinged skirts and eject from the Warzone or Pit. Repeat for Seggy
                  • #24
                    The Annihilators
                    For those who dont know, aka IDIOT is at full speed in 0.3 seconds. Unless you have the mother of all boxrushers (50+MPH), theres no way youll get to it before its at the full 1700RPM; at that speed, its KO-quality hits. One hit and youre gone.
                    As such, Ill be waiting for someone to have a go at it, and the same with Typhoon.
                    I dont expect to go anywhere due to my coincidental lack of luck in Martyns tournaments, with SpinVerter at its most effective unable to win a single fight (mainly through being somehow pushed down the pit :P). So to hell with it, Im ready for whoever wants some!
                    • #25
                      The Annihilators
                      so coming 4th and 6th in one series is bad luck tom?
                      • #26
                        The Annihilators
                        Come on, Tom, be optimistic!
                        • #27
                          The Annihilators
                          Segs tactics
                          I will use the vertical drum weapon, and at the start allow for the other two robots to play with each other before storming in with my middle-of-the-road speed but top acceleration to get around the sides and flip the robots around with the drum, so that I can push them sideways into the hazards/pit. Repeat with the other robot.
                          Storms tactics
                          Ram at Mechavore, get under the side using my extra speed and power and lift onto its back . Ram at the sides of Beta, and push into pit.
                          Disconstuctors tactics
                          Me and Tony are ganging up, as I will drive, the disc at full speed into his machine, which will hopefully knock out its weapon and prob the weapon on disconstuctor. Once thats done, keep away from shovearound and automatic schmuck as they play with each other, but in the background come into play and hit the sides
                          • #28
                            The Annihilators
                            Typo in Disconstuctors tactics:
                            Me and Tony are ganging up, as I will drive, the disc at full speed into Toms machine, which will hopefully knock out its weapon and prob the weapon on disconstuctor. Once thats done, keep away from shovearound and automatic schmuck as they play with each other, but in the background come into play and hit the sides
                            • #29
                              The Annihilators
                              Actually Dave, theres still a typo. Shovearound 2 isnt in that heat :P
                              • #30
                                The Annihilators
                                *Throws a potato at Toni (hehehe)*
