The Annihilators
Yep its time for a mini tourney, its pretty basic I need 3 robots from 6 people that will go into mayhems to qualify for a place in one of the annihilators if you go out of the mayhem first then you will go into the 18th-13th place annihilator if you go out second then its 12th-7th and if you win the mayhem 6th-1st.
Rules are
Each person enters 3 robots, one of which must be a real robot, one of which must be a vapour the other one is up to you it can be real or vapour.
The weight limits are as follows
100kg for a roller (tracked or wheeled)
125kg for robots that use screws
150kg for shuffle bots
200kg for €˜true€™ walkers (eg anarchy)
Flying robots are not permitted
Robots are allowed to be purely static
Clusterbots are permitted 100% has to be out for the cluster to go out, there is a maximum of 3 parts allowed
Try and include the basic minimum in the stats
For the rest basic robot wars rules apply
So get entering
Rules are
So get entering
(Nowhere in the rules said it had to be your vapourbot
