The Norman Sheppard Tribute Tournament
  • #46
    ah yes.
    Im tired, thats why.
    How on, I just read it again, I need to wear my glasses more, its only vapourbots 1 to 5 entered.
    • #47
      1. Gamma Trident
      Shape: A three-fingered claw, but with a rear curved wedge.
      Armor: 4mm hardox.
      Color: A kind of bronzish copper.
      Weight: 100kg.
      Speed: 11mph.
      Dimensions: 85cm x 80cm x 20cm.
      Weapons: A horizontal cutting blade spinning at 1500RPM, and the two clawed
      digits surrounding it are sloped wedges pointing at the blade.
      Ground Clearance: 0mm at the wedges, 1mm at the sides and middle-front.
      Srimech: Invertible.
      Strengths: Versatile, 4WD, tough armor.
      Weaknesses: Tricky to control.
      2. Splitz (a 4-way clusterbot)
      (for all Ss)
      Shape: Ziggo with flag.
      Armor: 2mm titanium.
      Color: S1 is black with blue 1 on top, S2 is red with black 2 on top, S3
      is green with red 3 on top, S4 is blue with red 4 on top.
      Weight: 25kg.
      Speed: 8mph.
      Dimensions: 35cm x 35cm x 12cm (no flag).
      Weapons: Bots can spin at 2000RPM, and have blades all over the body.
      Ground Clearance: 2mm.
      Srimech: None.
      Strengths: Considering the details, INCREDIBLY damaging. Hard to flip.
      Weaknesses: No srimech.
      3. Kick in the Teeth
      Shape: Wedge with rounded sides and back.
      Armor: 6mm titanium.
      Color: Silver.
      Weight: 96kg.
      Speed: 16mph.
      Dimensions: 95cm x 60 cm x 65cm.
      Weapons: A vertical flywheel spinning at 2500RPM, at the back of the robot.
      Ground Clearance: 0mm front, 3mm rest.
      Strengths: Good weapon, good turning.
      Weaknesses: 2WD, ground clearance bad when flipped.
      4. She Loves You
      Shape: A box with skirts
      Armor: 5mm hardox
      Color: Golden yellow
      Weight: 149kg
      Speed: 5mph
      Dimensions: 100cm x 85cm x 55cm
      Weapons: A 360 degree rotating double sided axe
      Ground Clearance: 0mm thanks to the skirts
      Srimech: Axe rights it best from the side.
      Strengths: Hard to push, a weapon with roaming ability
      Weaknesses: Slow because its a 8-legged walker, one weapon
      5. Balderdash
      Shape: Wedge from front, circle from top. In other words, a wedge-disc.
      Armor: 7mm titanium
      Color: Orangy-bronze
      Weight: 97kg
      Speed: 10mph
      Dimensions: 80cm x 80cm x 35cm
      Weapons: The top pops open to flip the opponent.
      Ground Clearance: 0mm front, 2mm rest
      Srimech: Flipper
      Strengths: Shape works very well against rammers, good armor.
      Weaknesses: No damaging weapon, 2WD
      6. 13 Black
      • #48
        Motors, batteries, speed controllers...etc, are missing , but...
        Shes probably inexperienced with that stuff. Give her a break, then. She IS my wife, you know
        • #49
          ah.
          If you include Speed Controllers I will just ingore it, because its one of the things you assume to be in the vapourbot.
          *Hides under handy table when Tom/Aaron come in and moan about how their speed controller allows their vapourbots perfect control etc etc*
          • #50
            Ok, here I am, ready for more action!
            Flippa Frenzay Mk 6
            Weight: 100 Kg
            Weapon: Bulldog Breed style flipper around the machine
            Can It Self-Right: Yes, flipper
            Movement: 4 wheel drive
            Shape: Low Wedge with wedges at sides and back
            Armour: 4mm Grade 5 Titanium
            Speed: 15 mph
            Power: 2 S28-400s at 36 V
            Turning Circle: 0m
            Ground Clearence: 0mm all around due to flipper and skirts/wedges, underneath skirts/wedges, 7mm at sides and back
            Summary: Last version got destroyed, so Im rebuilding.
            Strengths: Flipper, Tough To Get Underneath
            Weakness: High Ground Clearence Underneath Skirts
            Name: No Close Shave 2 (VAPOURBOT CHAMPIONS LEAGUE 2004 CHAMPION!)
            Weight: 100 kg
            Weapon: Razer Style Crusher, only better
            Can It Self-Right: Yes, Razer-Style Sri-Mech Wings
            Movement: 4 Wheels
            Shape: Razer-esque
            Armour: 5mm Aircraft Grade Titanium
            Speed: 13 mph
            Turning Circle: 0m
            Ground Clearence: 0mm at front, 5mm at sides at back
            Summary: New Robot, Me Old and Unrealistic version of this came 7th in FAHR 3
            Strengths: Great Weapon, Good Traction
            Weakness: Can Be Gotten Underneath By Lower Machines (Not At Front :P)
            4 real robots: Bulldog Breed, X-Terminator, Behemoth, and Tornado
            Hope everything here is ok!
            • #51
              And with Matt entering, I have all 16 people, so can:
              Andy
              Matt F
              Team Aussie
              Matt R
              Frank
              Get their final entries and stats in as soon as it is possible. Ta.
              • #52
                For my two robots Rogue and Intensity, go here:
                http://www.abbl.org/~teamvertex/teamaussie/index.htmwww.abbl.org/~teamvertex/teamaussie/index.htm
                Might as well let everyone have a gawk at the new stuff. Site will get some more info on my latest flipper bot and some more of Toms bots too, plus our joint bot Generator.
                • #53
                  Definite robots that I stated before, now just let me go Stat hunting
                  • #54
                    She Loves You
                    A Beatles fan! Cool!
                    Edit: Just because you are a Beatles fan doesnt mean Im going easy on you Clover
                    And you too Mr. McGregor!
                    Team Gore
                    http://www.geocities.com/kodybluz/kodybluz2
                    • #55
                      Team Odins real robot will be Tsunami. The rest are as follows-
                      1. Deep Impact 2
                      Shape: Low wedge (very similar to Double Agent in Battlebots 5.0)
                      Colour: Sky blue and black
                      Weight: 100kg
                      Dimensions: 100 x 60 x 30cm
                      Speed: 18mph
                      Turning Circle: 0
                      Ground Clearance: 1cm at rear and 0cm around the sides and the front
                      Armour: 2mm Hardox underneath 2mm polycarbonate.
                      Wheels: 2x inner Go-Cart wheels that come out at the top, so that Deep Impact 2 can run inverted.
                      Power: 2x Lynch 130s at 24 volts
                      Weapons: The weapons are the rear twin mounted carbon tipped vertical discs each spinning vertically like Nightmare, running at 1500rpm, and each machined from an extremely high density alloy that get all all their inertia and weight into the outer of the discs. Both discs get up to full speed in about 2.5 seconds.
                      NOTES: A much sleeker version of the previous Deep Impact. When DI2 is right way up, the discs spin vertically and are designed to flip opponents as well as damage. When DI2 is inverted the discs spin downwards and although damaging, are not as effective.
                      SRIMECH: Invertible
                      STRENGTHS: Powerful discs, good driving and speed.
                      WEAKNESSES: Weapon is not as effective when inverted.
                      2. El Persistance
                      SHAPE- compact invertible box shape with a front wedge (similar to Storm 2)
                      COLOUR- Black with red skirts
                      WEIGHT- 100kg
                      DIMENSIONS- 79 x 72 x 16cm
                      SPEED- about 16mph
                      TURNING CIRCLE- 0m
                      GROUND CLEARANCE- virtually 0mm all around due to skirts.
                      ARMOUR- 3mm Grade 5 titanium top and bottom, 3mm Hardox armour at sides, front and back.
                      WHEELS- inside robot, 6WD
                      POWER- 1 X 36v MagMotor
                      WEAPONS- After entering as a basic rambot last series, El Persistance returns with a Wedge of Doom style linear actuated lifting arm that can lift up to 200kg with two steel prongs attached at the end. The arm is designed to slide under opponents, lift them up till their wheels, tracks or legs no longer touch the ground, and then slam them into the arena walls with the full 20HP drive. The lifter is not designed to self right the robot.
                      SRIMECH- invertible
                      NOTES- When inverted it has Srimechs are still for wimps! written on the bottom.
                      STRENGTHS- Pushing power and impenetrable armour
                      WEAKNESSES- High ground clearance when inverted and lifter is not able to work when inverted.
                      3. Disco Dancer 2.5
                      SHAPE: Low invertible box with pointed front (similar to Fluffy)
                      COLOUR: Flourecent greeen
                      WEIGHT: 100kg
                      DIMENSIONS: 100 x 70 x 25cm
                      SPEED: 17mph
                      TURNING CIRCLE: 0
                      GROUND CLEARANCE: 2mm all around
                      ARMOUR: After Disco Dancers weak polycarbonate last series and then Tangos appalingly rubbish hardox in PTT4, I have decided to clad DD 2.5 in 3mm titanium.
                      WHEELS: 2 inner Go-Cart wheels
                      POWER: 2 X Sinclair C5 motors
                      WEAPONS: After being removed for PTT4 the twin Splinter style grabbing arms have been re-attached. The robots main weapon though is still the front mounted 20kg horizontal disc spinning at 2500rpm and taking 2.5 seconds to fully spin up.
                      SRIMECH: Invertible
                      Notes: Disc teeth painted bright red. The speed has been tonbed down this series for better control and manouverability.
                      STRENGTHS: Powerful disc, manouverable and more reliable.
                      WEAKNESSES: Unreliable armour in the past
                      4. 2blue
                      SHAPE- Low wedge with rear wedge
                      COLOUR- Lightish blue with 2blue written on the side in pink
                      WEIGHT- 110kg
                      DIMENSIONS- 110cm X 70cm X 45cm (inc. srimech)
                      SPEED- 12mph
                      TURNING CIRCLE- 0m
                      GROUND CLEARANCE- virtually 0mm at the front and back (thanks to the wedges), 15mm at the sides
                      WHEELS- 2 X rubber tracks
                      POWER- 2 X S28-400 Magmotors
                      WEAPONS- 2 x CO2 powered flippers one on each side
                      SRIMECH- 2 roll bars one to the front one to the back.
                      NOTES- Has a pink arrow on top to point which way is forward
                      STRENGTHS- Powerful weapons, Can self-right easily
                      WEAKNESSES- vulnerable to flippers at the sides
                      5. Avalanche
                      Shape: low wedge
                      Colour: White and light purple.
                      Weight: 100kg
                      Dimensions: 100 x 73 x 35cm
                      Speed: 18mph
                      Turning Circle: 0
                      Ground clearance: 0mm at front. Virtually 0mm around the rest of the robot
                      Armour: 5mm Grade 5 Titanium
                      Wheels: 4 wheeled. Wheels stick out of the top so Avalanche is invertible
                      Power: 2 X 36v MagMotors
                      Weapons: A 10kg Tornado style spinning flail set in the centre of the wedge. The whole robot mainly acts like an avalanche. If anything gets in its way, it will plow straight through it without stopping!
                      SRIMECH: Invertible
                      NOTES: Has Avalanche painted on the top and bottom in red
                      STRENGTHS: High pushing power and tough armour
                      WEAKNESSES: Lack of damaging weapons
                      • #56
                        *Armour: 2mm Hardox underneath 2mm polycarbonate.*
                        2mm Hardox doesnt exist, Hardox 450 @ 3.2mm is the thinnest you can get.
                        • #57
                          1. Your High-density alloy - Unobtanium?
                          2. The only way you could do that is to actually HAVE all the weight in the rim. You cant machine something so that it goes somewhere else.
                          • #58
                            Hope this is OK...
                            1) Son of Ripper 4.0
                            2) ForcePower Turbo
                            3) Wedga Revo
                            4) GeForce
                            5) GigaByte (New Robot)
                            6) Typhoon 2 (Real Robot)
                            Stats for all the vapourbots at http://mattyhakaman.proboards15.com/index.cgi?board=AJhttp://mattyhakaman.proboards15.com/index.cgi?board=AJ
                            • #59
                              If you made a thin flywheel with a thick rim and put weight reducing holes in the thin part, you could achieve something like that effect. Im not about to comment on structural stability though
                              • #60
                                Unobtanium is very lightweight but strong ans anything and is totally indestructible.
                                Hardox is good for making flywheel rims, bolting them to an aluminium core makes the weight distro way better for energy purposes too.
