NSBFL 7
  • #61
    NSBFL 7
    Urgh, sorry...
    Just one thing, stats in books and on TV are totally different from the ones you have to produce for FanFic tourneys. IMO this game is all about the stats, the better the more chance you have of winning. Just because it says Diotior runs on 3x 12v batteries it doesnt mean thats the only thing that drives it.
    Sorry about the baseplate stuff, but giving me examples does not explain how it is done.
    I quote once more:
    *Note: This is not a rant, or a moan, or insults it is part of I feel like improving Chris vapourbots today.org*
    I have just been through the worst two weeks of my life... I apologise about your grandfather I have just been through a similar situation over the said two weeks. :sad:
    • #62
      NSBFL 7
      What happened?
      • #63
        NSBFL 7
        Nosy...
        • #64
          NSBFL 7
          No...wondering what kind of thing that is similar to my Grandfather dieing that Andy suffered.
          • #65
            NSBFL 7
            Trust me, hes told me, and you dont want to know. I registered and fully sympathise with you Chris, but this is even worse.
            • #66
              NSBFL 7
              If you really want to know, give me an e-mail.
              • #67
                NSBFL 7
                Sorry to hear both of you are having a rough time... But, hey, if were playing for sympathy, Ill see your bad fortnights and raise you a crap 3 months
                • #68
                  NSBFL 7
                  ORKA MK3
                  Weight-95kilos
                  Shape-Box
                  RML-Panzer MK3
                  Speed-12mph
                  Locomotion-6 inner-solid tyres
                  GC-2mm, with 0 at scoop
                  Armour-6mm titanium
                  Weapons-Electric lifting shovel at front, could lift a bus,
                  Srimech-A top mounted dorsal fin rights the robot either way up.
                  Strengths-Cant run out of CO2
                  Weaknessess-Hard to turn
                  DIE CERATOPS INVERTUS
                  Weight-100 kilos
                  Shape-Box with moveable nose cone
                  Dimentions-1.3m x 0.78m x 0.28m
                  Speed-18mph
                  Locomotion-4 inner, solid tyred
                  GC-2mm, 0mm at flipper
                  Armour-6mm titanium
                  Weapons-Invertable flipper, like St Agro, or Rick. It can flip 300 kilos. The nose cone is moveable so the flipper can still work upside down.
                  Srimech-Robot runs inverted. See above for flipper working upside down. Bars prevent side stranding.
                  Strengths-Ability to work upside down and STILL be able to use its weapon
                  Weaknessess-Control
                  Name-Cyclone Force 2
                  Weight-100 kilos
                  Body Shape-Once again, Storm 2 type box, with skirts
                  Speed-25mph
                  Armour-3mm Polycarbonate
                  Power-A couple of LEM 130s
                  TC-0
                  GC-Variable at front depending on set-up, 0 at side due to skirts, 1mm at back.
                  Weapons-Unlike last time, this robot has not one, not two, but THREE weapon set-ups.
                  1-STORM 2 SET-UP-The robot has a front wedge and a Storm 2 type lifting arm, able to lift the same as Storm 2 (about 100 kilos proven, possibly 150). The front GC is 0mm in this set-up. THIS SET-UP DOES NOT WORK UPSIDE-DOWN!
                  2-KAN OPENER SET-UP-Here, the robot has a pair of Horizontal Crushing arms, like Kan Opener, crushing at about 8 tons PSI. It should pierce anything up to what Razer can pierce. GC at front is 1mm. This set-up works upside down.
                  3-DISC-O-INFERNO SET-UP-Here, the robot has a horizontal flywheel, spinning at about 1000rpm. To get an idea of what it can damage, think back to Disc-O-Inferno back in Series 6, and the Extreme Annihilator. GC is 1mm at front, but thats the least of its worryies. Again, this set-up is invertable.
                  Srimech-The robot is invertable. Set-ups 2 and 3 work upside down.
                  Strengths-Raw Power
                  Weaknessess-Hard to control, Set-up 1 does not work upside down, I hate making decitions!
                  • #69
                    NSBFL 7
                    By the way, if you have any problems with any of these, you need to consult Dave S. He actually helped me fine-tune Cyclone Force 2.
                    • #70
                      NSBFL 7
                      I need the turning circle for Orka and DCI
                      • #71
                        NSBFL 7
                        Its 0. Most of my robots are. I hate having wide turning circles.
                        • #72
                          NSBFL 7
                          Thats fair enough, but I dont like having to guess with stats as 9/10 Ill guess wrong
                          • #73
                            NSBFL 7
                            There are 14 people entered, so I need another two. Any takers?
                            Mat R, you still have two BIIBId robots (Ankle Biter and Deep Impact IIRC)
                            Chris M you have one BIIBId robot (Crush 2)
                            Nick, so far you only have Parasite entered, but I still have the stats for ABR. Do you want to enter that as well?
                            Also, does anyone want a list of real robots Ive found they can use?
                            • #74
                              NSBFL 7
                              Is this concerning the things you mentioned earlier. Because...
                              1-4mm Hardox
                              2-8 tons of downward force when it comes in for the kill.
                              Anything else?
                              • #75
                                NSBFL 7
                                Should be good now.
