NSBFL 7
  • #31
    NSBFL 7
    quote:
    Chris M - I think LBB is a bit overweight, but not enough to BIIBI it.
    I do, he has 6kg in Boschs, with at least 3kg in batteries, a weapons system, topped off with 6mm polycarb, all in 20kg. It would be believable if it was weaponless.
    BIIBI!
    • #32
      NSBFL 7
      Just a quick robot off the top of my head. You all know that im not brillant with exact specs, so ive tried to give a rough idea. If its unrealistic, tell me how and ill try to fix it...or you could give me advice on how to make it more realistic
      Anyways
      Name: Vampire Twins (Two way cluster)
      Dimensions (mm): 120x60x20 each
      Shape: Box shaped with skirts on each side except the back
      Colour: Black with splotches of blood
      Ground clearance: 2mm on the three skirted sides, 3.5mm at the back.
      Weight distribution: 50/50 (50 KG each)
      Power: Each bot has a Bosch motor
      Top speed: 15mph
      Weapons: Each twin has two drills powerful enough to pierce all but the toughest armour (stay the hell away from 6mm hardox ). The front skirts also flip up (to help with self-righting) so they could be counted as weapons
      Armour: 5mm Titanium
      Mobility: Four wheels on each bot, the wheels are protected by the skirts which are also there to reduce ground clearance. If a skirt was taken off, the ground clearance would go up to 15mm (same as the back)
      Turning circle: 5mm
      SRIMECH: The skirts flip up to self right the bot.
      The linkup is magnetic, both sets of drills could be spinning at the same time if the clusters were together.
      Strengths: High powered drills. Low ground clearance. Creatures of the night (ok so that€™s stupid but I wanted another )
      Weaknesses: If a skirt got hit the right way, it could jam against a wheel ala Hypnodisc (I think, coulda been Razor) with it€™s wheel arch. Both parts are light separately (That€™s a given). If tthe front skirts are removed, no SRIMECH
      • #33
        NSBFL 7
        quote:
        What I mean is, if every shot hits, say, the right corner, then fair enough. But if some hit the right, and some hit the left, then it would take more hits.
        Shouldnt matter. The thing spins clockwise, so hitting the front right corner would be damaging the front side of it more. Hitting the front left corner would hit the side part of it more. Either way, its a corner. All points on the weapon are equivalent to all the other points.
        • #34
          NSBFL 7
          Not Scott (thats the lamest name ever, BTW), is your name Frank? NO. He says its just about OK, its just about OK. Besides, its been accepted in other tournies.
          • #35
            NSBFL 7
            Do you actively try to start arguments?
            • #36
              NSBFL 7
              Well, he certainly doesnt do it passively
              • #37
                NSBFL 7
                his name is Not Scott but his user name is Scott so it kinda contradicts it self
                • #38
                  NSBFL 7
                  I said in the rules that Scott couldnt reserve places, as he always forgets about said places and needs some serious prodding to enter, so he changed his name to Not Scott as a joke :P
                  In the interests of ending this argument, Chris, is it OK to reduce LBBs armour from 6 mm to 3?
                  • #39
                    NSBFL 7
                    OK, 3mm will do.
                    • #40
                      NSBFL 7
                      Save me a place in evrything thats left... if there is anyhting please!
                      • #41
                        NSBFL 7
                        NAME- The deer (was crusher chaos)
                        SHAPE- Invertible box
                        COLOR- the robot and claws are a dark green color
                        WEIGHT- 100kg
                        DIMENSIONS- 1m x 80cm x 25cm
                        SPEED- 15mph
                        TURNING CIRCLE- 0mm
                        GROUND CLEARANCE- It has 6mm at the front due to the claws and has 0mm at the sides and rear without skirts 6mm. The skirts also work both ways up.
                        ARMOUR- 3mm hardox
                        MOVEMENT- 4 inner wheels that make the robot invertible
                        POWER- 2 x S28 Magmotors on 24v.
                        WEAPONS- it has a front pair of horizontal hydraulic crushing claws set up like deers antlers like you fine in extreme destruction. The claws have 3.5 tones of crushing force on the front tips of the claws at the middle is 6tones and right at the back it has 8 tones of crush. The claws are powered by hydraulics through a 120mm bore rams at 3000psi
                        NOTES- invertible, wide base means I wont topple while the deer is crushing
                        STRENGTHS- Very powerful weapon
                        WEAKNESSES- it could be turned into venison
                        Name- Panicking (previously panic 3 GTI 2)
                        SHAPE- Low invertible box
                        COLOUR- White
                        WEIGHT- 98kg
                        DIMENSIONS- 65cm x 60cm x 18cm (Length x Width x Height)
                        SPEED- 23mph
                        TURNING CIRCLE- 0 mm
                        GROUND CLEARANCE- 0 mm at front due to forks, 0 mm at sides and rear due to skirts 5 mm with out, the skirts are hinged so flop over when the robot is flipped
                        ARMOUR- the robot is now covered in 5mm hardox
                        MOVEMENT- panic now uses 6 Vulcalon wheels to give extra pushing power
                        POWER- 2 x LEM130€™s on 36 volts
                        WEAPONS- on the front the robot has a pair of invertible lifting forks, the forks are like those on panic attack, the forks are powered by 2 linear actuators
                        STRENGTHS- Low ground clearance, reliable weapon
                        WEAKNESSES- previously lost to spinners
                        NAME- Happy birthday party pooper (previously Birthday party pooper) (ta to frank for the help he gave me with finalising this robot)
                        SHAPE- invertible disc (like gyrobot)
                        COLOUR- Blue
                        WEIGHT- 150kg
                        DIMENSIONS- 100cm diameter X 20cm height
                        SPEED- 10mph
                        TURNING CIRCLE- 0mm
                        GROUND CLEARANCE- its about 10mm but 3mm under the blades
                        ARMOUR- 6mm titanium body
                        MOVEMENT- it runs on 8 inner anarchy style legs.
                        POWER- 2 x S28-400€™s Magmotors on 24v.
                        WEAPONS- it has a powerful spinning shell spinning at around 1500rpm weighting around 65kg powered by 2 X LEM-130s running at 48v, it has 12 typhoon2 style teeth around the out side 4 around the bottom 4 around the middle and 4 at the top
                        NOTES- all components have been shock proofed with rubber around them.
                        STRENGTHS- very destructive weapon
                        WEAKNESSES- easy to push if weapon not spinning
                        NAME- Call out hook
                        SHAPE- low box wedge (like storm 2 but not invertible)
                        COLOUR- red and black with gold diamonds on it, the hook and axe weapon are silver
                        WEIGHT- 100kg
                        SPEED- 23mph
                        TURNING CIRCLE- 0mm
                        GROUND CLEARANCE- 0mm at front wedge, 0mm at sides due to skirts 6mm with out 6mm at rear, varies under weapons
                        ARMOUR- 4mm hardox
                        WHEELS- 6 inner Vulcalon wheels
                        WEAPONS- Weapon- On the top of the machine, there is a 360-degree rotating turret, on which can be mounted 2 weapons. The first one is a large CO2 powered lifting arm, running off a 80mm ram at a pressure of 750psi. It has a hook shaped arm on the end, which is designed to pull up and puncture wheels, whilst lifting at the same time, and also to enable it to penetrate skirts. This ought to lift around 268kg around 40cm into the air at maximum. The other weapon that can be chosen is a double-headed horizontal axe shaped like that of Terrorhurtz, which will spin around on the turret, enabling him to do both damage by spinning and hammering. This should be enough to cut thin titanium, and dent the thicker sheets. The turret is powered by a LEM 130 geared at 4:3 giving good speed it spins at around 2000rpm and reaches it in around 3-4seconds
                        SRIMECH- the lifting arm which can self right from any position due to the turret
                        STRENGTHS- good weapons, good pushing power
                        WEAKNESSES- if the arm is spinning round it may topple
                        NAME- It may be small but its still bad and pink
                        SHAPE- invertible box
                        COLOUR- Pink
                        WEIGHT- 59kg
                        SPEED- 20mph
                        TURNING CIRCLE- 0
                        GROUND CLEARANCE- 0mm under front scoop, 0mm under sides due to skirts 6mm with out.
                        ARMOUR- 3mm titanium
                        WHEELS- 4 inner vulcalon wheels
                        POWER- 2x LEM130 Lynch Motors on 24v
                        WEAPONS- it uses a front 3mm hardox scoop which has a chain flail spinning vertically
                        SRIMECH- invertible
                        STRENGTHS- good rammer
                        WEAKNESSES- hard to control
                        spikey 2 and my feather weight will be up later
                        • #42
                          NSBFL 7
                          Hold on i shall withdraw It may be small but its still bad and pink as its over weight and find a new middle weight
                          • #43
                            NSBFL 7
                            Seems I cant reserve places, can someone please tell me why, Ive got to be honest, I dont know why. Ive always got stats in for every tournament Ive wished to enter...
                            If you want a rough guide to my enteries:
                            FW - Overdrive (please dont BIIBI it, I am trying to build it )
                            LW - Possibly Gridlock EVO
                            MW - Slizer, if I cant get anything better done
                            HW - SOR, ForcePower, Psyclone, Wedga for now, will probably change
                            Ill get all my stats up as soon as I can, if Im allowed... :P
                            • #44
                              NSBFL 7
                              quote:
                              WEIGHT - 150kg
                              Do I smell a BIIBI?
                              • #45
                                NSBFL 7
                                What does BIIBI mean?
