Velociraptor's Fanfic Tournament - Series 6!
  • Velociraptors Fanfic Tournament - Series 6!
    FYI, Richie, the only link between Doomsday and La Machine is the similar shape and as for Football, stick in RotRotB to replace Chameleon
    And as for the Doomsday Inspiration guesses...way off!
      Its Dr Robotnik, from Sonic, isnt it?
        Its the cooker from A Grand Day Out, isnt it?
          *ding ding ding*
          Hot dog! We have a weiner! Scotty wins 300 virtual pounds from my account and all those lurverly Brownie points
          To be more precise, the concept of Doomsday came from the Sonic toon they made back in 93/94. During this summer, I was channel surfin, trying to find the video for Michael by Franz Ferdinand , when I stumble upon the toon again nearly 10 years since its last broadcast. Id forgotten how much it rocked
          As for the clues:
          - The Doomsday Project - comes from the last show
          Today, Knothole. Tomorrow, the world! - reference to the Hedgehogs home
          - Past cool, eh? - oft used in the Hedgehogs vocabulary
          - a gleaming red eye on either side of the main weapon - a reference to the last image in the final show. Yep, it still haunts me today
          So the truth is uncovered, Scotty wins and Richie now knows what kind of puns to use in Doomsdays intro
            Steve, might I suggest checking around 440 to 480 on Sky for the music channels
              I did, but it was never on there, so I tried all the others
              The God Channels a good laugh, too :P
                Do you have all the BBC1 regions?
                  Steve, if you want Michael, just watch Q for an hour. Then youll find it. In fact, you cant miss it:P
                  Cool song too
                  As for Dr. Robotnik.... do you have a life
                    Some of my Entries:
                    Name: Mother Of All Bricks 2(MOAB)
                    Motivation: 8 shuffling plates
                    Speed: 18MPH
                    Weight: 10kg
                    Height: 150mm
                    Length: 550mm
                    Width: 550mm
                    Weapon: A single 300g 3.6v cordless screwdriver with a deadly sharp diamond tipped drill.
                    Drive: 4 x B42-500 Magmotors on 48v with two stage planetary gear boxes driving 8 shuffle plates which have 30mm wide by 450mm long strips of Volcalon rubber giving it more traction then any robot around! Each drive motor is producing 32HP each! Giving it a whooping 128HP (Take that Storm II)!
                    Batteries: 160 C Cell NiCD Battle Packs producing 48v @ 12amps!
                    Armour: 7mm Hardox 700 ware all over the robot, there is 58 KG in armour alone!
                    Notes: Invertible, Fast, Tough and has skirts made out of 6mm Hardox which are connected via 20mm silver steel pins and locks. The skirts are invertible and are torsion sprung with a force of 85kg, this works both ways up, no flippers getting under this baby .
                    Motivation: 4 WD
                    Speed: 5MPH
                    Weight: 100.00kg
                    Height: 200mm
                    Length: 600mm
                    Width: 600mm
                    Weapon: The weapon to be honest is over kill. It€™s not there to win battles with precision or by advantage, it€™s there to win by pure ignorance and brute force. Gyrate features a 27kg 4ft long flybar, with two big teeth on the ends. The weapon is powered by three Husqvana chainsaws(same ones from Executioner 2) which produce 17HP at 24000rpm. The weapon is geared 3:1 to bring the 27kg blade down to a calm 8000rpm at peak. The blade according to the Team Cosmos Kinetic calculator, will produce 1.45 MEGA JOULES, not Kilo Joules, but MEGA! With a tip speed of some what close to 1500km/h, the weapon gives off sonic booms from the blade! Spin Up time, around 3-4 secounds. To sum it up, this weapon is not a toy, it has one purpose, to destroy anything and everything that enters its way, even if it means destroying itself in the process(the weapon that is). As they say, it doesn€™t matter weather you win by an inch or a mile, winning is winning.
                    Drive: 2 x S28-150 Magmotors with 30:1 planetary gearing, geared heaps so the motors will take the strain and load.
                    Batteries: 20 x 3000mAh NiCD cells to produce 24v 3amp. Just enough to last a full 6 mins.
                    Armour: 2mm poly. The opponent has to get past the huge spinning bar first though!
                    Notes: A one Hit Ko Machine
                    Advantages: The biggest, most powerful spinning weapon around
                    Disadvantages: No Armour€¦..
                    Name: Mass Disctruction Ultimate 3.1
                    Motivation: Wheels
                    Speed: 18MPH (480MPH Tip Speed)
                    Weight: 100kg
                    Height: 170mm
                    Diameter: 0.8m
                    Weapon: The robot itself is the weapon. It uses its drive and a custom made micro processor system similar to that used in a fellow translational spinner called Cyclone Bot to translate itself around the arena creating a €œVortex of Destruction€. Using 9 Hardox €œenlightened€ teeth, it tears its opponent to pieces when the teeth collide at a sub-sonic speed of 480MPH. Causing certain death to the opponent.
                    Drive: 3 x B42-500 Magmotors running on 48v. The motors are protected with a current limiting circuit and a thermal protection system which will ensure the motors don€™t over heat. The drive system uses a unique variable drive system with load sensing technology which enables the robot to start rotating with a high gear ratio preset at 10:1 giving the motors high torque low speed. As the robot gains rpm, which is constantly monitored via wheel rpm sensors, the gearing then adjust to suit the load of the motors and gain further speed allowing the gear ratio to lower from 10:1 to as low as 1:1 at top speed. The gear ratio can also over drive thrown the ratio 1:2 giving the robot nearly double the original top speed and allowing far more energy, but this is only used when the opponent is at a distance where it can easily be disposed of. Otherwise, the drive is left at 1:1 maximum.
                    MDU 3 sports an advanced drive control system to that of Cyclone Bot as it uses motor and wheel sensors to travel and translate in the most efficient possible way, minimising energy lose. The drive will adjust ratio to suit condition if it is loaded and will change if need to translate at the full 18MPH (10MPH up on the last version since the robot size has decreased for faster movement, quicker spin up times and thicker armour). Spin up time is minimal and varies between 0.5sec spin up and 1sec when the system is suffering from battery voltage drop. At a mere 1/7th of its full RPM, this robot will be dangerous. 500rpm will have enough energy to throw robots out the road and allow it to continue it quest for domination. If people start ganging up on it (Everyone will, I know), the drive system will be locked down into 500rpm mode allowing the drive to have nearly maximum potential torque yields and it will force the opponents away till it can then safely power back up to full speed and deliver the force of the €œVortex of Destruction€. To ensure endurance during combat, everything has been shock mounted for maximum protection.
                    Batteries: 160 x 5000mAh D Cell producing 48v @ 15amps. The packs are protected by a system like the drive which give both current and temperature protection. The packs are re-enforced between the cells with thermal conducting Aluminium plates which support the batteries from the G-Force at max speed.
                    Armour: 6mm Hardox 500 with stainless steel welding. Built in a monocoque design with triangle shape and inner supportive bulkheads.
                    Notes: Invertible. Dangerous and soon to be, your worst nightmare. All within your precious 100kg weight limit. Approche Avec prudence.
                    Advantages: Ultimate handling, with the ability to strafe, dodge and attack with out changing orientation.
                    Weakness: Stevo€™s Writing j/k Umm, probably itself.
                    Name: The Ultimate Wedge
                    Motivation: 6WD
                    Shape: A wedge shape like Voltronic
                    Speed: 35MPH
                    Weight: 100kg
                    Height: 250mm
                    Length: 800mm
                    Width: 600mm
                    Weapon: A High Pressure top hinged flipper powered by a 80mm bore with 3 20mm Burket valves feed from a 3L buffer tank, using 2.2L of Liquid CO2. Well over 500kg of flipping force. This is not designed to be a big powerful flipper, but is used to launch the opponents over the arena wall or to momentarily disable them so they can be rammed again! Flipper sits on top of the armour, meaning when the flipper fires, the robot is still armoured everywhere.
                    Chassis/Armour: 4mm Hardox 400
                    Drive: 2 x LEMCO 200€™s! Bigger then the LEMCO 130€™s and they put out more HP!
                    Batteries: 160 x 3000mAh NICD to produce 48v
                    Notes: The robot is invertible.
                    Advantages: The SPEED! The Pushability! The Strength! Flipping good
                    Disadvantages: Having to keep your opponent in the arena long enough to have fun
                    RIP CAGE & INFUSION COMING SOON!
                      Isnt the doomsday project from a side saga of the original spiderman comics where the villian red skull tries to use the abandon doomsday device by collecting the several sacred keys of the original builders. Some reason I think Captain America gets involved in this.
                        FYI, Haka, I finally found the Michael vid in the end ...and as for your last comment, I just have a long memory. Were all sad in our own way . Why do you think were on this Forum in the first place?
                        BTW Richie, would we be able to get a list of all the bots in so far, vapours n all?
                          Here it is, Steven:
                          2Blue - Matt R
                          Aces & Eights - Tom B
                          Ankle Biter The Second - Matt R
                          Annoying Box Rush - Nick
                          BADer - Frank
                          Battle Rat - Nick
                          Bender - Tom B
                          Biohazard - Matt R
                          Black Chalkie Beard - Dave S
                          Back On The Chain Gang - MHF
                          Bulldog Breed - Matt MacDonald
                          Chaos 2 - Steven
                          Chip - James
                          Cholera - Chris Mason
                          Cuffy - Dave S
                          Dallas - Daniel
                          Dantomkia - Tom B
                          Deep Impact 2 - Matt R
                          Dervish V/ - Daniel
                          Dieceratops Invertus - Chris Mason
                          Disco 5 - Martyn
                          Disco Dancer 2.5 - Matt R
                          Disconstructor - Dave S
                          Dominator 2 - James
                          El Persistence - Matt R
                          Firestorm V - Frank
                          Flippa Frenzay Mk6 - Matt MacDonald
                          Flipping Mad TU - Dave S
                          Forcepower Turbo - AJ
                          Forklifts Revenge - Martyn
                          Geforce - AJ
                          Growling Storm 2.5 - Matt MacDonald
                          Gyrate - Aaron
                          Hacked Off Ha-ka - MHF
                          Happy Birthday Party Pooper - Martyn
                          Hassocks Hog 2 - Tom B
                          Hypertension Mk2 - MHF
                          Infernal Contraption - Tom B
                          Infusion - Aaron
                          In-terror-fied - MHF
                          Iron Awe 3 - James
                          Juggerbee 3.0 - Chris Mason
                          Killer B - Tom B
                          Killotine Evo - Steven
                          Leprosy Infection - Chris Mason
                          Little Sister - Tom B
                          Manic Monsoon - Daniel
                          Mass Disctruction Ultimate 3.1 - Aaron
                          Megabyte - James
                          Mega Masher 2 - Chris Mason
                          M.O.E - Nick
                          Mother Of All Bricks 2 - Aaron
                          Mr Nasty - Daniel
                          Nightmare - Nick
                          No Close Shave 2 - Matt MacDonald
                          Not Another Pushover 2 - Matt MacDonald
                          National Speed Limit Applies - Dave S
                          NSBFR-X - Frank
                          Orka Mk3 - Chris Mason
                          Overkill - Chris Mason
                          Panic 3 GTI 2 - Martyn
                          Pink Panther - Matt R
                          Powerpoint Reaches Pressurepoint - MHF
                          Push-Ish - Dave S
                          Psyclone - AJ
                          Pulveriser - James
                          Razer - Aaron
                          Revenge of Revenge of the Bludgeonator -Steven
                          Ringmaster - Daniel
                          Rip Cage - Aaron
                          Rippoff Yet Again - Matt MacDonald
                          Roo 2 - MHF
                          Scimiter - Frank
                          SD IV - Steven
                          Seggy The Third - Dave S
                          Squish - Daniel
                          Sonic Boom - Daniel
                          Son Of Ripper 4.0 - AJ
                          Srimech Not Included - Martyn
                          Star 69 - Martyn
                          Starstorm 2 - Frank
                          Stinger - James
                          Storm 2 - Matt MacDonald
                          Supernova - James
                          Surgeon General - Matt R
                          Tazbot - Nick
                          Tempest: Evil-er-ution - Frank
                          Terrorhurtz - Tom B
                          The Crashing Bore - Frank
                          The Disc 4 - Frank
                          The Doomsday Project - Steven
                          The Raven - Steven
                          The Ultimate Wedge - Aaron
                          TIRTASM - Martyn
                          Tough As Nails - AJ
                          Tsunami 2 - MHF
                          Typhoon 2 - Martyn
                          VGer - Nick
                          Vlad the Impaler 2 - Nick
                          Voltronic - Nick
                          Warhead - Aaron
                          Wedga Revo - AJ
                          Wedge Devolution - Steven
                          Wedgie 5 - Dave S
                          Wheely Pure Evil 2 - Daniel
                          Whirligig 4.0 - Steven
                          Windchiller - Matt MacDonald
                          Windier Killer Just Got Windier - MHF
                          Wrecktangle - Chris Mason
                          WX 6.0 - AJ
                          X Terminator - James
                          Ymir - AJ
                          Could you please get your entries together, Scott? Remember one of them must be real.
                            BTW, Its just SOR now, because Ripper has been on TV.
                              And its WindiEST Killer Just Got Windier:P
                                Oh, and to Steve, it was meant to be a joke. Im only saying that because you didnt take it as well as I thought you would
