Velociraptor's Fanfic Tournament - Series 6!
  • Velociraptors Fanfic Tournament - Series 6!
    quote:
    If feasible, team up with Dieceratops & damage MDU with disc
    *Raises Eyebrows*
    Yes, it definitely works
      I dont beleive there are CPZs either...
        AJs right, Tom - the arenas a box with a pit that opens for 10 seconds, and a horizontal disc in a corner.
        Steven - yes, I know exactly how picking winners feels!
          Bull. Those I intended to throw OOTA Ill push into pit quickly, even those I wouldve intended to shove in *alleged* CPZs then
            I think you (Steve+Tom) are forgetting the change round. Tsunami 2 and No Close Shave have swapped.
            Slight change...Now, I WILL post tactics now.
            MAIN WARS
            CHOLERA (Heat B)
            Stay away from Manic Monsoon and attack the other two, lifting them up and pitting them.
            ORKA MK3 (Heat D)
            Attack Pink Panther
            JUGGERBEE 3.0 (Heat E)
            Stay away from SOR
            OVERKILL (Heat G)
            Straight for SNI
            LEPROSY INFECTION (32, Heat I)
            Attack Dominator 2
            DIECERATOPS INVERTUS (Heat M)
            To Reply to Tom: Unlikely, since we are not fighting Tsunami. Attack IC and stay away from the seed.
            MEGA MASHER 2 (Heat N)
            Try to stay on the same side as the seed, team up, and work it out from there.
            WRECKTANGLE (Heat O)
            Stay in a league with Killotine and attack the others. Try to stay on the same side as the seed.
            EVENTS
            DIECERATOPS INVERTUS (Annihilator contest)
            Just attack anything
            WRECKTANGLE (AC)
            Team up with Psyclone in his bid to get rid of The Disc and work it out from there
            LEPROSY INFECTION AND MEGA MASHER 2 (Football)
            See stats for changes made to robots for this event. Mega Masher will be in goal, sideways, using all the body to block the goal. Leprosy Infection will be attacking the ball and scoring the goals.
            JUGGERBEE 3.0 (Challenge Belt)
            Depends on the oppodents, but the basic idea, whatever oppodent I have, is to ram.
            And there you go.
              HEAT A
              The Disc 4 (1) vs Biohazard (Me) vs Infusion vs Panic 3 GTI 2
              Slide under whoevers the closest, lift them up and parade them across the arena before hopefully dumping them into the pit.
              Heat C
              Warhead (21) vs 2Blue (Me) vs Iron Awe 3 vs Not Another Pushover 2
              Team up with Warhead and go for Iron Awe and toss him around the arena, and then go for No Another Pushover
              HEAT D
              Windiest Killer Just Got Windier (7) vs Cuffy vs Orka Mk3 vs Pink Panther (Me)
              If Chris wants to team up, Ill go for Windiest Killer. Ill be using the Wedge of Doom lifting arm for this battle.
              Heat E
              Achilles (25) vs Chip vs Hefty Kick In The Balls vs Surgeon General (Me)
              Team up with Achilles, take on HKINB and try to damage him as much as possible with the disc.
              Heat G
              Wheely Pure Evil 2 (29) vs Deep Impact 2 (Me) vs Revenge Of Revenge Of The Bludgeonator vs Seggy The Third
              Team up with ROROTB and go for Wheely, aim for the wheels and try to cut them off with the discs.
              Heat I
              Leprosy Infection (32) vs Disco Dancer 2.5 (Me) vs Dominator 2 vs Tengu VI
              Team up with Tengu and go for Dominator. Ill will aim for his sides as much as possible and my aim aim will be to flip him over and then rip off his axe whilst hes trying to self right.
              HEAT J
              Angel Of The Abyss (14) vs Ankle Biter The Second (Me) vs B.A.Der vs Flippa Frenzay Mk6
              Team up with AOTA and aim for Flippa Frenzay. Hit him as much as possible with the drum, inflicting hopefully major damage!
              Heat K
              Forcepower Turbo (2 vs Disconstructor vs El Persistence (Me) vs The Raven
              Go for Disconstructor and slam him around the arena as much as possible. Then go for Forcepower and try to do the same.
                Okay, here are my tactics!
                Whirligig 4.0 (19) vs Battle Rat vs Growling Storm 2.5 vs National Speed Limit Applies
                Go for Battle Rat first, and grab onto its side with the jaws and push it down the pit, then go after National Speed Limit Applies, and team up with Whirligig 4.0 to take it out, as the spinner on Whirligig 4.0 should do some mean damage to NSA, hopefully immobilising him, then try and get NSA down the pit.
                Warhead (21) vs 2Blue vs Iron Awe 3 vs Not Another Pushover 2
                Team up with Warhead. Ill go in and easily pit Iron Awe 3, which shouldnt be any problem at all, while Warhead goes after 2Blue and trashes it, it should easily do so, then I shall get underneath the high ground clearence of 2Blues sides and pit it, this should not be a problem at all!
                Disco 5 (23) vs Bulldog Breed vs Killer B vs Starstorm 2
                Flip Killer B up on its side, or on its back if it cant self-right, then pit it. Once that easy job is out of the way, Ill manouver to the side of whoevers easier to get underneath without taking damage, and pit them too!
                Son Of Ripper 4.0 (9) vs Back On The Chain Gang vs Juggerbee 3.0 vs Rippoff Yet Again
                Go for Juggerbee 3.0, as its the weakest of the three out there, I shouldnt have any problem at all immobilising it with the disc! Then, Ill team up with Son Of Ripper 4.0 and immobilise Back On The Chain Gang, this shouldnt be a problem with its vulnerable wheels, and the armour shouldnt stand up to well on BOTCG either!
                The Crashing Bore (15) vs Constrictor vs In-terror-fied vs Storm 2
                Team up with The Crashing Bore. In-terror-fieds weapon cant do anything to me, so I should easily get underneath it and toss it down the pit. Then either Storm 2 or The Crashing Bore then should easily send Constrictor to the pit!
                Angel Of The Abyss (14) vs Ankle Biter The Second vs B.A.Der vs Flippa Frenzay Mk6
                As much as Matt thinks Ankle Biter The Second is good, its actually rather rubbish, so I should easily be able to avoid its weapon, and flip it around, and to the pit. Then team up with the more deadly machine and take out the other one.
                Mass Disctruction Ultimate 3.1 ( vs Dieceratops Invertus vs Infernal Contraption vs No Close Shave 2
                Simple plan here, team up with Mass Disctruction Ultimate 3.1 and I shall grab onto Infernal Contraption and pit it while MDU 3.1 beats the living sh!t out of Dieceratops Invertus!
                Dervish V/ (22) vs Mega Masher 2 vs Total Bast**d vs Windchiller
                Its Wind Chiller by the way, two names, not one. Anyways, If Danny would like to team up in this one, then Wind Chiller can go for Mega Masher 2 and pit it by getting underneath it from the side and bringing it to the black square hole in the ground, while Dervish V/ can attack Total B**tard.
                The should all work hopefully according to plan.
                  Having noticed a technical error in Doomsdays stats (TY, Mr Knight :P), I would like to exchange the Etek powering the weapon with an LEM-170 (36v) and upgrade the drive to 36v too.
                  Hope thats OK, Richie
                    I is back. Arriva still suck, I dont care who you think is worse, Arriva is actually officially the worst train service around.
                    Stats up monday at the latest, but then theres another problem... NTL (My ISP) is undergoing maintenance and I cant get online without using my sisters computer. This isnt a BIG problem, its just Disc 4 and Tempest need KJ and weight checking and I need the online KJ checker
                    Although as I said... Monday at the latest, and thats not a promise, its a fact.
                      Hey, Matt, never complain that a person is over-cocky, then BE over-cocky yourself.
                        Just giving people a taste of their own medicine Chris.
                          As we wait for Franks Stats
                          *Pulls up chair*
                          Who wants to play a game of cards?
                            *tips dave off chair and runs off faster than anyone with it*
                              *Picks up another chair from pile in waiting room*
                              Tactics up later, just yet me try to do something with my firewall, which ATM is going haywire.
                                I will post my tactics before each heat, because it will be easier.
