Dinowarrior Destruction
Ill enter Marabunta, Impact Weapon, Indisctructable, Montys Pass, Crusha & a new entry, TB87. Pic on profile.
Weight: 97kg
Body Shape: Storm 2
Power: 2 9hp LEM 130 Lynch motors generating 18hp
Speed: 25mph
Ground Clearance: 2mm
Armour: 5mm Grade 5 titanium
Locomotion: Wheels, all inner, 6WD
Weaponary: A Storm 2 style-lifter
Srimech: N/A, its invertable
Strengths: Fast & maneuverable
Weaknessess: Exposed wheels & weapon cant be used when upside down
Weight: 99kg
Body Shape: Constrictor
Speed: 20mph
Ground Clearance: 1mm
Armour: Carbon fibre & 4mm Grade 5 titanium
Locomotion: Wheels, all inner, 4WD
Weaponary: A 1000psi C02 flipping arm
Srimech: Invertable & can self-right using the arm
Strengths: Quick, maneuverable & good weapon
Weight: 98kg
Body Shape: Storm 2
Speed: 23mph
Armour: 6mm Grade 5 titanium, built like a tank
Weaponary: None, built like a tank
Srimech: Invertable
Strengths: Fast, maneuverable, good control & toughness
Weaknessess: NONE!!
Weight: 97kg
Body Shape: A heavyweight clone of Cutlet 540
Speed: 18mph
Armour: 4mm Grade 5 titanium
Weaponary: A full pressure C02 flipper
Srimech: Can self-right using the flipper
Strengths: Fast, agile & good weapon
Weaknessess: Limited C02 supply
Weight: 98kg
Body Shape: Kan Opener
Speed: 12mph
Locomotion: Wheels, all inner, 2WD
Weaponary: 3000psi hydraulic crushing jaws & rear mounted battering ram
Srimech: Invertable
Strengths: Good weapon & low ground clearance
Weaknessess: Exposed tyres
Weight: 97kg
Body Shape: Fluffy
Speed: 12mph
Armour: 3mm Grade 5 titanium topped with 2mm polycarbonate
Weaponary: A bi-rotational IG88 spinning axe mounted horizontally which rotates at 2000rpm
Srimech: Invertable
Strengths: Powerful weapon & low ground clearance
Weaknessess: Wheels vulnerable to attack from above
Weight: 97kg
Body Shape: Storm 2
Speed: 25mph
Weight: 99kg
Speed: 20mph
Weight: 98kg
Body Shape: Storm 2
Speed: 23mph
Srimech: Invertable
Weaknessess: NONE!!
Weight: 97kg
Speed: 18mph
Weight: 98kg
Speed: 12mph
Srimech: Invertable
Weight: 97kg
Body Shape: Fluffy
Speed: 12mph
Srimech: Invertable
