Re: The tournament formerly known as FFW
I'll give tactics as and when fights come up...for my realies, I shall do whatever the real robot would have done, and for Pain, I invite you to make your own judgement Zarte ;P
Eye of Ran II vs. Volcano: It's Paul again! Hiya! *waves*
*looks at Volcano's stats, notes the shockproofing hasn't changed, and reaches for gas mask in case of combustion of polyurethane foam*
Eye of Ran has a longer blade reach (~40cm in front of the robot), its blade is lower than Volcano's teeth are by about 20mm, and some previous investigations on the RW101 forums show that spinners of that type are inherently unstable and prone to flipping themselves over. Nonetheless, it does have a Large Spinny Thing (tm), so I shall try and avoid hitting that. Spin up, and always present the front of the spinning weapon to Volcano, don't let it get an edge of any sort on the main body, and basically just keep hitting it below where the teeth on its own weapon reach. Something will happen at some point, I think the better shape and lighter weight of EoR's bar will let me spin up again between hits better than Volcano, and the clutch on the weapon should prevent it taking that much damage.
Good luck Paul, and good luck Zarte ^^
I think that if I can get round the back and get under the rear skirt with my wedge, I can tilt Eye of Ran II upwards from the rear end, effectively forcing its spinning bar to eat the arena floor and stall. At that moment I can keep on top of it, and like the previous battle, push it into the house robots and the other hazards, preferably the pit. If it does manage to spin up at any point, I am confident that my armour and the lifting wedge can take the impacts. I also think that in the (admittedly unlikely) event I can turn it over, Eye of Ran's bar will not be able to hit Exertion II - something worth trying, perhaps... Just generally stay aggressive and try to get it down the pit.
