Re: The tournament formerly known as FFW
Add in Killotine: EVO (same as always) and Venus Fly Trap II for me, ta.
Venus Fly Trap II
SHAPE- box with wedges on all sides
COLOUR- green with ugly great mouth on top
WEIGHT- about 100kg, I hope.
DIMENSIONS- 95cm X 95cm X 20cm
SPEED- 12mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 10mm, though the wedges and spatulas should provide some extra protection
ARMOUR- 3.75mm Hardox
MOVEMENT- 4 x inner wheels
POWER- 2 x C40-500 MagMotors. These will run at 36v and produce approximately 12hp.
WEAPONS- On either side of Venus Fly Trap II is what appear a rear-hinged flipper with a large spatula, covered in barbs. These are the 'jaws' and are powered by an 80mm x 120mm pneumatic ram each, running at 250psi. The idea is that an opponent is scooped up on top of the robot or gets stuck on one of the spatulas, the 'jaws' fire simultaneously and ensnare it like a real venus fly trap.
SRIMECH- A rear-hinged arm on top. Powered by a separate S28-400 MagMotor geared 250:1 for quick and easy self-righting.
NOTES- flies Scotland flag, thanks to Joey for aiding in the design
STRENGTHS- Unique weaponry, powerful, well-protected, nimble
PIC- http://img394.imageshack.us/img394/7102 ... trapii.png
Venus Fly Trap II
SPEED- 12mph
TURNING CIRCLE- 0mm
Well since I have to give viable tactics, uh...drive straight at Sauron, hit it, and stop moving due to utter failure? :P
