Fanfic Wars - Series 1
  • Storm II (2) vs. Hefty Kick in the Balls
    • Storm II
      • Hefty Kick In The Balls to win this one.
        • Heat P Final
          Storm experienced the exact same problem they did in Round 1. They managed to get in some good shoves, but when HKitB managed to get a good enough hit to flip them, they were helpless. Well, not entirely, but they could not shove the Scotland spinner around at all. HKitB turned and used the sloped rear to wedge Storm II and send the 2nd seeds around. Just before the end, they gave Storm one more hit which flipped them back over, but also damaged a side panel greatly. Storm lost the judges' decision.
          All right, here's the first of the semis!
          Semi Final 1
          Raging Tempest vs. Flick of the Wrist
          Envy vs. Black Panther
          Dantomkia (15) vs. Ripper (22)
          Tira VI vs. Hypno-Disc
          SCOREBOARD
          AJ - 146
          Joey - 119
          Tracy - 107
          Lian - 95
          Jack - 56
          Lewis - 49
          Martijn - 48
          Dan Bailey - 22
          playzooki - 15
          Alex H - 13
          A Wafer Thin Mint - 9
          Samuel - 5
          Zarte - 5
          • Flick of the wrist
            envy
            ripper
            TirA
            • Raging Tempest vs. Flick of the Wrist
              • Semi Final 1
                Round 1
                Flick's armour just wasn't enough. After evading the forks for a while, Tempest tore through it like butter, and a few hits later Flick was rendered immobile.
                Team Bud marched on, as Envy tossed about the Black Panther, and Team DoomForAll's entry met its end in the pit after a lot of flipping.
                Sorry, Mike, Jonno got one over you here. It was a fairly even match, but Dantomkia was ejected from the arena after being tossed against the wall and struggling to self-right against it.
                The old horizontal vs. vertical argument couldn't be more wrong here. Tira's disc put a noticeable bend in Hypno-Disc's after they collided. Tira's weapon was compromised too but they had no damage to their disc, but Hypno-Disc was completely boned after losing their weapon. Tira used the rear to get under and flip them repeatedly. Hypno-Disc lasted to the judges but that was as far as they got; Tira won a unanimous decision.
                Round 2
                Tira VI vs. Envy
                Raging Tempest vs. Ripper (22)
                SCOREBOARD
                AJ - 153
                Joey - 119
                Tracy - 107
                Lian - 95
                Jack - 56
                Lewis - 49
                Martijn - 48
                playzooki - 24
                Dan Bailey - 22
                Alex H - 13
                Samuel - 5
                Zarte - 5
                • Tira and tempest
                  • Tira VI vs. Envy
                    • Round 2
                      Tira VI vs. Envy
                      Not fun for Team Bud. They drove up onto Tira's front prongs flanking the disc and got their wedge blade dismantled. From then on they had extreme difficulty getting under the spinning machine and only once got under and flipped them, from which Tira self-righted. Tira won the decision and was the first robot into the Grand Final.
                      Frank's run ended here. Ripper got its front bashed in almost completely, but by then Tempest's ring has stalled. From there Ripper opened the pit and JUST managed to pit Tempest with 2 seconds to go.
                      Semi-Final 2
                      Quaestor III vs. Hefty Kick in the Balls
                      Monsoon Magnum vs. Iron Awe 5 (17)
                      Wedge Devolution vs. Infusion
                      Razer vs. Typhoon 2 (1)
                      SCOREBOARD
                      AJ - 153
                      Joey - 119
                      Tracy - 107
                      Lian - 95
                      Jack - 56
                      Lewis - 49
                      Martijn - 48
                      playzooki - 32
                      Dan Bailey - 22
                      Alex H - 13
                      Samuel - 5
                      Zarte - 5
                      • HKITB
                        Iron awe 5
                        Wedge devo
                        typhoon
                        • Quaestor III vs. Hefty Kick in the Balls
                          • Semi-Final 2
                            Round 1
                            It surprisngly went the distance, as Quaestor didn't get knocked out, but nor could he tip HKitB over. In the end it went to a judges decision, and they went in favour of Hefty.
                            Only one robot was going to stay in the arena. The other robot went out halfway through the match... via Iron Awe's flipper. The seed marched on.
                            Wedge Devo held on until the end, where they got Infusion down the pit. The Aussie machine put up a fight though.
                            Surprisingly, Razer were able to keep up with the Scottish spinner, and mid-way through the match managed to pin them against the wall. Unable to get a good grip on them, they pushed Typhoon into Sir Killalot's CPZ, who proceeded to smother Typhoon against Razer. Razer chomped and finally got a hold on them, and then dragged Typhoon into the pit.
                            Round 2
                            Razer vs. Iron Awe 5 (17)
                            Hefty Kick in the Balls vs. Wedge Devolution
                            SCOREBOARD
                            AJ - 162
                            Joey - 119
                            Tracy - 107
                            Lian - 95
                            Jack - 56
                            Lewis - 49
                            Martijn - 48
                            playzooki - 41
                            Dan Bailey - 22
                            Alex H - 13
                            Samuel - 5
                            Zarte - 5
                            • Razer
                              hkitb
                              • Razer vs. Iron Awe 5 (17)
