Fanfic Wars - Series 1
  • Xterminator 3 and Eye of ran
    PCC and Beast
    • X-Terminator 3 (4) vs. Hypertension Mk 3 vs. Eye of Ran II vs. Infusion
      Tiberius 4 (29) vs. Death Adder 3 vs. P.C.C. vs. Beast
      • Heat O
        Round 1
        X-Terminator was dealt the death blow after several hits from Eye of Ran, but then Infusion went after it and attacked it. While Joey was kept busy, Hypo drove into Eye of Ran, got under, and ejected it!
        An unfortunate result for Dave Shep, as P.C.C. was set upon by Tiberius early on and pitted. Beast meanwhile unsuccessfully attempted to throw Death Adder 3 out of the ring, but failed. Then Death Adder managed to lodge its axe into Beast's front flipper. As they were busy mingling, Tiberius came over and chomped into the rear of Beast, sensing weakness! Together, Death Adder and Tiberius threw Beast down the pit!
        Round 2
        Tiberius 4 (29) vs. Hypertension Mk 3
        Infusion vs. Death Adder 3
        SCOREBOARD
        AJ - 126
        Joey - 119
        Tracy - 107
        Lian - 90
        Jack - 56
        Lewis - 49
        Martijn - 48
        Dan Bailey - 22
        Alex H - 13
        A Wafer Thin Mint - 9
        Samuel - 5
        Zarte - 5
        Ouch, tough luck again playzooki. Keep trying, though!
        • Hypertension and infusion
          • Tiberius 4 (29) vs. Hypertension Mk 3
            • Round 2
              Fairly disappointing. Hypertension missed a hell of a lot with its flips, and the two it managed to get sent Tiberius into 360s, which delighted the crowd. Sadly, it was grappled and pitted halfway through the match.
              Okay, personally I like Death Adder 3. How often do you find a shuffler with an axe? Anyway, that's besides the point, because Infusion just tore through that titanium ring like a hot knife through butter and strew its internals everywhere.
              Heat O Final
              Tiberius 4 (29) vs. Infusion
              SCOREBOARD
              AJ - 129
              Joey - 119
              Tracy - 107
              Lian - 90
              Jack - 56
              Lewis - 49
              Martijn - 48
              Dan Bailey - 22
              Alex H - 13
              Samuel - 5
              Zarte - 5
              playzooki - 3
              playzooki finally gets on the board, but it looks like AJ's running away with the huge lead!
              • infusion
                • Tiberius 4 (29) vs. Infusion
                  • Heat O Final
                    Tiberius was a tough nut to crack, but after a few hits, they stopped moving entirely. Evidently something had been jarred loose, but Infusion used their kinetic boost to shove Tiberius down the pit before the count-out came.
                    Heat P
                    Storm II (2) vs. Orka MK4 vs. Kronic vs. Hefty Kick in the Balls
                    IG-88 (31) vs. Mass Disctruction Ultimate 4 vs. Flipping Hell vs. Axeon 4.0
                    SCOREBOARD
                    AJ - 134
                    Joey - 119
                    Tracy - 107
                    Lian - 90
                    Jack - 56
                    Lewis - 49
                    Martijn - 48
                    Dan Bailey - 22
                    Alex H - 13
                    playzooki - 8
                    Samuel - 5
                    Zarte - 5
                    • Storm II (2) vs. Orka MK4 vs. Kronic vs. Hefty Kick in the Balls
                      • Storm II and Orka
                        MDU and Axeon
                        • Heat P
                          Round 1
                          The Scottish vertical spinner certainly showed what it was made of in this fight. Kronic went after them and wished it didn't - the Wedgehog got knocked straight over onto its back and its flipper plate was dislodged! It fired the ram but was unable to right itself! Storm II meanwhile had gotten around Orka's sides and gave it a momentous SLAM against the side wall, scattering its wits. But Hefty came back in and flipped Storm II right over! Storm tried to ram Hefty but found it ineffective when inverted, and just to assert its dominance, Hefty smacked Orka just as Orka had self-righted and threw it sideways against the wall! They also attacked Orka's self-righting fin before Orka could use it, but it didn't matter because the same hit sent flying over the fence! However, Storm finally managed to get some offense in post-fight by slamming Hefty into an empty CPZ from the side.
                          Well IG-88 wisely avoided the spinning translational spinner, at least, until Flipping Hell managed to get under them and fling them over. But by then, Axeon had gotten to Flipping Hell's sides and start pounding them. IG-88 was declared immobile and could only watch as MDU4 slowly spun in and resulting hit completely destroyed the side panel of the spinner, ripping it right out and sending it spinning into a corner, electronics gushing out! Axeon then pressed its advantage, shoving Flipping Hell into MDU4 before the mighty 3 wheeled bot could spin back up, and threw them into Sgt. Bash's CPZ. Bash clamped onto MDU4 and dragged them to the flame pit... but Flipping Hell was already dead from Axeon's hammer abuse. They were counted out.
                          Round 2
                          Storm II (2) vs. Mass Disctruction Ultimate 4
                          Axeon 4.0 vs. Hefty Kick in the Balls
                          SCOREBOARD
                          AJ - 136
                          Joey - 119
                          Tracy - 107
                          Lian - 90
                          Jack - 56
                          Lewis - 49
                          Martijn - 48
                          Dan Bailey - 22
                          Alex H - 13
                          playzooki - 12
                          Samuel - 5
                          Zarte - 5
                          • mdu
                            hkitb
                            • Storm II (2) vs. Mass Disctruction Ultimate 4
                              • Round 2
                                The fearsome spinner was pinballed into the walls a few times, and the weakened Storm managed to finally get hold of them and pit them. The loss of armour panels is telling, though...
                                Axeon got a huge shot in on the side and punctured HKitB's soft armour, but then the Scotbot turned and nailed Axeon over. Axeon self-righted but HKitB knocked them right back over. When Axeon finally managed to escape the blows it was moving sluggishly, and HKitB caught up with it a short time later and kicked it back over. A few more hits and Axeon couldn't move.
                                Heat P Final
                                Storm II (2) vs. Hefty Kick in the Balls
                                SCOREBOARD
                                AJ - 141
                                Joey - 119
                                Tracy - 107
                                Lian - 90
                                Jack - 56
                                Lewis - 49
                                Martijn - 48
                                Dan Bailey - 22
                                playzooki - 15
                                Alex H - 13
                                Samuel - 5
                                Zarte - 5
                                Last fight, then we go to the semis! More points to be had there!
