CAD requests
  • CAD requests
    hey guys i was wondering if any one could possiby do a render of my bots
    heres the list and the stats
    Archmage
    Weight: 13.6kg
    Shape: The same shape as Pillow Torque, except for the lifter which partially sticks out the front.
    Colour: Dark blue, with a blood red stripe down the middle.
    Dimensions: 47cm x 30cm x10cm
    Drive: 2 Astroflight C40 motors, using a 15:1 reduction, powered by a 19.2V 3700mAh NiMh Battlepack.
    Locomotion: 4 Pillow Torque-style wheels.
    Armour: 3mm titanium
    Speed: 10mph
    Ground Clearance: 0mm at front. 4mm elsewhere.
    Turning Circle: 0m
    Weapon: A 4-Bar electric lifter, powered by an Astroflight C90 motor. It can lift 75kg.
    Srimech: Invertible, but the lifting arm can self-right it.
    Strengths: Fast. Reliable lifter.
    Weaknesses: Exposed wheels.
    Bio: Lian Walsh's first featherweight design. Essentially Pillow Torque with a new paint job and a 4-bar lifter. Many thanks to Leo Van Miert and Jamie McHarg for helping to fix the stats.
    The Servant
    Weight: 100kg
    Shape: Mute (S7)
    Colour: Blood Red
    Dimensions: 67cm x 96cm x 26cm
    Drive: 4x 24v S28-400 Magmotors powered by 5x NiCad Battlepacks
    Locomotion: 4 Mute-style wheels.
    Armour: 5mm titanium
    Speed: 35mph
    Ground Clearance: 0mm at front, 5mm elsewhere.
    Turning Circle: 0m
    Weapon: A full-pressure rear-hinged Co2 flipper(looks a lot like Chaos 2's) powered by a fire extinguisher using a 70mm bore 100mm stroke ram. It can flip 500kg.
    Srimech: Flipper
    Strengths: Very fast.
    Weaknesses: Untested in battle
    Bio: Essentially an updated Mute, Team Blood Mages' Servant is prepared to do some damage
    Dr. Thwack
    Weight: 100kg
    Shape: Biohazard.
    Colour: Malachite green
    Dimensions: 80cm x 75cm x 10cm
    Drive: 4x 24v S28-400 Magmotors, powered by 3x 3000mAh NiCad Battlepacks
    Locomotion: El Diablo Grande-style rubber tank tracks.
    Armour: 4mm hardox
    Speed: 20mph
    Ground Clearance: 0mm all around thanks to 3mm titanium skirts. 5mm without skirts.
    Turning Circle: 0m
    Weapon: A 10kg pneumatic hammer, powered by a fire extinguisher using a 90mm bore 200mm stroke ram. It hits an opponent at 70mph.
    Srimech: The hammer.
    Strengths: Powerful weapon, nearly unflippable.
    that is all thank you, please reply to me if you have the time to do it thank you
    Re: CAD requests
    i think im losing popularity lol
      Re: CAD requests
      Apologies, but do you really expect people to respond to you after 29 minutes, bearing in mind this part of the forum's been more inactive than it has for a while?
      Please have some more patience.
        Re: CAD requests
        ok sorry mate :P
          Re: CAD requests
          Sorry, I couldn't resist...
            Re: CAD requests
            LOL!!! I can't believe you would actually do that.
              Re: CAD requests
              ...I can XD
                Re: CAD requests
                Who wouldn't :P
                  Re: CAD requests
                  thats a bit random
                    Re: CAD requests
                    Due to me needing a lot of practice and having thought about it for a while, I am now doing CAD's to the level of outer shell or rough internals (unless someone can point me in the direction of some robot parts models).
                    Finally a basic sketch would be nice for more complicated designs.
                      Re: CAD requests
                      I dont need one for Dr Thwack or The Servant anymore
                      (AJ has done them for me )
