Re: VRW Series 4
Alright... Our round 2 battles...
Whiplash (1) vs Firestorm 5
Our house robots will be Dead Metal and Shunt.
3..2..1..Activate!!!
And in comes Whiplash, immediately turning and getting around to the back of Firestorm 5. Apparently, Pete wasn't able to fix the motors, as Whiplash comes down with the axe, crumpling into the aluminum armor. Firestorm doesn't appear mobile, as Whiplash runs all the way to the other side of the arena. The finalist now charges towards Firestorm, knocking the former Robot Wars finalist into Shunt's CPZ. Shunt comes in with the axe, causing more damage to the armour, and in comes Dead Metal, coming down with the saw and causing even more damage to the exterior of Firestorm 5. The Guardian now enters the scene, as it lands and counts out the wreck that was Firestorm 5...
1..2..3..4..5..6..7..8..9..10!
And now, Shunt presses the pit release bumper, as Dead Metal shoves Firestorm down. Ha ha! And Whiplash shoved Dead Metal down as well!
Firestorm 5 is burned out...
WHIPLASH (1) GOES ON TO THE HEAT FINAL!!!
Starfire the 4th vs Maximum Genocide (6)
Our house robots will be Sir Killalot and Matilda.
Starfire spins up its disc, as Maximum Genocide also spins up both of its weapons. Suddenly, Starfire bolts forward, knocking both machines back from the point of impact. Starfire is now moving slowly with a massive gash in the actuating arm, but Maximum Genocide isn't moving at all, seeing as one of its wheels is caught on the arena wall. However, the wheels are still spinning, and so is that blade! But its too late, as Starfire once again bolts forward, miraculously ramming the 6th seed onto the camera tracks.
Maximum Genocide loses! The 6th seed won't be killing for a while...
STARFIRE THE 4TH MOVES ON TO THE HEAT FINAL!!!
So here's the heat final:
Whiplash (1) vs Starfire the 4th
 vs Gyrobot vs Terrorhurtz vs Tornado
 vs Gyrobot vs Terrorhurtz vs Tornado Well, I still have 7 more chances; so I'm not complaining at all.
 and gravity's flipper, get round the back of ant opposition and pit them
