Re: VRW Series 3
Shape:box wedge,dimensions are,1m long,0.75m wide and 0.5m high at the back.
Chassis:6mm mild steel
Armor:6mm hardox(f)6mm ti(b+s)
Weapon:a co2 full pressure flipper at 750psi with 1 110mm ram,and a 2kg bottle,the arm is hinged at the back and made of 8mm mild steel
Battery:2x 12v sla's wired in series
Motors:2x magmoters at24v
weight:98kg's
Wheels:2x go-cart wheels
Ground clearance:0mm at the front,and 2mm at the sides and the back
Speed:10mph
Turning circle:0m
tornado: ram him from the rear and sides, push him into cpz's or into side walls (something might pop out...
) if i cant finish him that way i'll open the pit and push him in
im running the disk set up here, dont stray to far away from the middle (keep away from side walls (unless IM pushing lol
typhoon:lol spin up and try and k.o him, if all else fails ram the side walls!!!
razer: crush, if not koed push into teh pit
CroOkEd: go for the O.O.T.A! push into cpz of pit if necessary!
weight:98kg's
Speed:10mph
Turning circle:0m
