FRFFT: The World Championships
    Re: FRFFT: The World Championships
    Welcome to FRFFT: The World Championships! First up, we have a featherweight battle between 360 and Overdrive.
    As usual, there won't be any house robots except Refbot.
    From the UK, 360!
    Entered by Joey, 360 is basically a smaller version of Hypno-Disc, but still as dangerous. The disc can cause heavy damage, but it is light, and could be pushed around.
    From England, Overdrive!
    Entered by AJ, this robot is a box on wheels that rams its opponents and pushes them around the arena. Its fast, but how effective will it be?
    Roboteers, stand by!
    3-2-1: Activate!
    What a way to begin the World Championships! 360 spins up and tries to get around the side of Overdrive, but AJ turns to push 360 from the side! OH! And into the wall! The disc has stopped spinning! Overdrive tries to push it again, but 360 backs away. Overdrive gives chase, but 360s disc has spun up to full speed. Overdrive charges in...OHH! Sparks fly and Overdrive is spun away a bit. No damage, the armour is quite strong. 360 comes in again, but Overdrive just charges head on again. It pushes 360 to one side but gets clipped by the disc. Joey gets away to the centre of the arena. Overdrive goes...where is it going? The pit release! It presses the button, down goes the pit. 360 needs to avoid that and chases after Overdrive. Overdrive doubles back and hits 360 again! Pushing it around and ALMOST into the pit! 360 gets away. Overdrive pushes from the side and onto the flame pit. 360 gets away again, but Overdrive pushes back. It's faster, Overdrive, at 15mph. Is the disc on 360 still working? Its spinning slowly. Now, Joey pushes Overdrive around and into the wall. Overdrive gets away and turns to push 360 toward the CPZ, but 360 turns away. I think all this pushing around has slowed 360 down. It turns around, but Overdrive is relentless and pushes it into the wall again! Joey tries to get away, but Overdrive pushes from behind and towards the PIT! 360 on the edge! Overdrive pushes again and OHH. Down goes 360! What a fight! Unlucky, Joey. Well done to Overdrive.
    Cease!
    360 in the pit.
    Overdrive goes through to the final!
    Sorry if that was short and a bit uncreative. Its been a while since I've written anything.
    Liam, I assume your robors are represnting Wales. Are you still here?
    Joey, where is everybody? Just wondering.
      I need some advice.
      I don't know if everyone from the old forum has checked into this one yet, which is a problem because I don't know if Liam is here. I need his country for this and his tactics.
      I know its slow moving at the moment, but I don't think the FRFFT chain will continue very long. Like I said, you may have known this forum was coming, but I didn't. I'm not too sure why, though
      Sorry for any inconvenience
        Quick tip...the new forum came into being on 18 March. Anyone who has posted since then is aware of the new forum and has logged on it (Liam has, for example, but as he says in the Easter Bunny Championships thread he's on holiday and can't get online), and I think most of the community have found it (the only worrying exception is Lewis, who hasn't been seen in a while)
        And like I've said before you should have seen it coming, the announcements made, the emails sent and the fact the old forum now leads to a redirect page should have helped there.
          I haven't cancelled this. I believe in fairness, so I'll wait for Liam and Lewis to post their tactics for this. Until then, I've decided to stay on real robots for now. Hope you understand
            You'll be waiting a long time then, because Lewis hasn't re-registered on the forum.
              Liam entered the legends competition I started yesterday. He is swimm3r, isn't he?
                Yes, but you said you would wait for Lewis as well. He hasn't re-registered.
                • #23
                  Sorry Elliot, I forgot about this, but remember you can go ahead after a few days or so if you want because tactics aren't essential
                  Featherweights
                  360 (UK) VS Overdrive (England) ~ ....
                  Micrompression (UK) VS Small System Shock (Wales) ~ Rami taround and try to get it down the pit.
                  Middleweights
                  Steel Sandwich (Canada) VS Hyper Ventilate (UK) ~ Hyper-Ventilate to win by pitting or stacking or whatever
                  The Eviscerator (Wales) VS Typhoon (Scotland) ~ Spin up, hit until death :P
                  Heavyweights
                  Vengance (UK) VS Fissure (England) ~ Fissure for a pitting.
                  Toad (Wales) VS N3 (UK) ~ Not sure Toad will be any good... Will try anyway though :P Use the spike setup and try to hook then pit it.
                  Superheavyweights
                  Omega Rex (Wales) VS Drive (UK) ~ Flip OOTA ASAP.
                  Vertigo (UK) VS Uberforce 2.0 (Germany) ~ Duno anything about either of these two :P.
                  Good luck everyone
                  • #24
                    Welcome back to FRFFT: The World Championships.
                    Next we have a middleweight battle
                    From Wales, The Eviscerator!
                    Entered by Liam, a box with a spinning blade on the front. Its invertible and well armoured, but the wheels are exposed to crushers and axes.
                    From Scotland, Typhoon!
                    Entered by AJ, the Robot Wars Middleweight Champion. It hasn't had any real success in FRFFT, but will that change here?
                    3-2-1: Activate!
                    Two spinning robots here, so its interesting. The Eviscerator swerves to avoid the dangerous weapon on Typhoon, who charges right at the side! The Eviscerator backs out of the way just in time, but Typhoon turns and OHH! It hits the front of The Eviscerator and the sparks fly! The Eviscerator recovers and backs into Typhoon, whose weapon has been slowed by the impact and pushes it over the flame pit! Thats not good, the electrics will burn out there! AJ gets away as The Eviscerator presses the pit release button. Down goes the pit and they want to avoid that. Typhoon still hasn't spun up to full speed yet, and I wonder if it was damaged? The Eviscerator turns into it again and the blade creates more sparks on the armour of Typhoon! It hasn't made any real damage to the shell, but Typhoon is pushing back! It pushes The Eviscerator into the wall. Liam pushes back, though and towards the pit! Typhoon breaks free as The Eviscerators weapon spins again. A close match so far, but The Eviscerator on top I think. OUCH! The two collide again and Typhoon is knocked away. The Eviscerator closes in, but backs out because...Typhoon isn't moving! Did that impact knock it out? Maybe. The Eviscerator hits it again! Sparks fly, but Typhoon is just nudged into the angle grinder. AJ can't do anything about it! Refbot comes in.
                    1-2-3-4-5-6-7-8-9-10!
                    The Eviscerator can do whatever it wants to do to Typhoon now. The front spinning blade RIPS into the armour! It has laid into it. Liam switches off the blade and backs into Typhoon again, pushing it towards the pit and down they go! Typhoon, out in Round Two of Series Two, but no furthur will they go here!
                    Cease!
                    Typhoon blown apart!
                    The Eviscerator goes into the next round!
                    Next up, the heavyweights, including Vengance and Fissure
                    See you later
                    • #25
                      Next, we have two heavyweights: Fissure and Vengance!
                      From England, Fissure!
                      A box wedge shaped robot with a lifting spike in the middle, this AJs latest heavyweight creation. Its manourvable but there is a high ground clearance at the back.
                      From the UK, Vengance!
                      A six wheel drive box wedge armed with an axe, this is Lewis's entry into the heavyweights. It has lots of force at the front, but it only has 20 axe hits per fight.
                      3-2-1: Activate!
                      Vengance is off to a quick start, but avoids Fissure! Why, I wonder...OH! That's why, to get under the side! AJ turns Fissure around to try and get the lifting spike under the skirts of Vengance, but Vengance pushes it towards the arena wall! OHH! It just RAMMED Fissure against the wall and Fissure crashed away. Its recovered, but Vengance hits it on the top with the axe! Fissure turns to get under the front but Vengance is just too fast and gets under again! Down comes the axe, but Fissure gets away! It turns to get the spike under Vengance's skirt, but Lewis backs away. Fissure gives chase. A good battle so far. Vengance suddenly doubles back and tries to push Fissure away, but Fissure has gotten under the front wedge! It lifts it up, but not over! Vengance strikes it again with the axe, but Fissure is unfazed and tries again, backing Lewis into a CPZ! Vengance pushes Fissure away and onto the flame pit, then goes to the pit release! Down goes the pit, and they'll have to avoid that now, these two. Fissure moves to the centre of the arena to try and get under Vengance again, but Vengance turns faster and scoops under Fissure, pushing it towards the angle grinder! Fissure pushed against it, but Lewis backs away, allowing it to get free. Down comes the axe of Vengance, onto the top of the titanium armour of Fissure, which has withstood it so far. Now Fissure gets under Vengances front again, and starts to slowly lift it up! Vengance fires its axe, but it does nothing to help it escape! Fissure tries to push it over, but the spike has gotten caught in one of Vengances wheels! Six wheel drive in Vengance, but it can't use that 20mph speed to get away right now! Fissure turns around and pushes Vengance towards the pit. Lewis tries to get free of Fissure, but Fissure has control and towards the pit it goes...down goes Vengance! A good start by them, but Fissure made good on it exposing itself for a short while and finished it.
                      Cease!
                      Vengance won't be getting any!
                      Fissure goes into the next round.
                      Next time, the superheavyweights!
                      I'm not too sure what to make of this. I have a feeling it won't be up to your standards, mostly because of Lewis's absence. I do hope he returns, though.
                      • #26
                        Good fight, there, still lacking slightly in detail but getting better, even moreso than before.
                        Don't feel too disheartened by Lewis' absence, ELLIOT; I had to deal with Tony not showing up for most of C&B2. XD
                        • #27
                          Next, we have the first superheavyweight battle of the FRFFT World Championships between Vertigo and Uberforce 2.0
                          From Germany, Uberforce 2.0!
                          A fast box wedge with six wheels, Uberforce could force the opposition aide here! Entered by AJ, it entered a previous FRFFT series, but the wheels are exposed.
                          From the UK, Vertigo!
                          Entered by Lewis, Vertigo is another box wedge with six wheels, but is armed with a powerful flipper. It is made from Hardox, but once the Co2 runs out, it may be feeling as its name suggests!
                          3-2-1: Activate!
                          Two evenly matched robots, but with different weapons. Uberforce makes the first move and RAMS Vertigo into the angle grinder! Vertigo recovers to get around the side of Uberforce and THROWS it into the air! Aggression already by both robots. Uberforce is right way up, so its wedge can still work. It backs away, closly followed by Vertigo. Now Uberforce doubles back and tries to get around the side, but Vertigo is much faster and OHH! It got under first and hurled Uberforce up against the wall! AJ tries to get away, but all six wheels have been taken off the ground. Will Vertigo throw it out? Its just watching Uberforce, but suddenly moves forward and pushes Uberforce off the wall and lets it go! Was that wise for Lewis to do, because Uberforce quickly recovers and starts pushing at the sides of Vertigo, but it can't get under those skirts. Vertigo turns, but Uberforce backs away, so Vertigo is flipping at thin air. It regains itself and chases after Uberforce, who is in the centre of the arena. Vertigo RAMS into Uberforce again, but doesn't flip! Uberforce turns as Vertigo comes back for another go, but this time it gets out of the way! They size each other up, but Uberforce can't do anything unless Vertigo is facing the front, where there are no skirts. Vertigo swerves into the side of Uberforce again and OHH! Over it goes! This time, its upside down, Uberforce, so the wedge is useless. The judges look on. Uberforce presses the pit release button. Vertigo slides under the inverted wedge and FLIPS again! Uberforce was almost in the pit there! It gets away over the flame pit. Vertigo follows. The last ten seconds of the clock count down. Uberforce CRASHES into the side of Vertigo again and pushes it against the wall using the rear part instead of the wedge. Vertigo turns to flip it one more time.
                          Cease!
                          A good battle. The judges will make their decision!
                          Uberforce 2.0: S: 2 C: 2 D: 1 A: 3 Total: 8
                          Vertigo: S: 3 C: 3 D: 1 A: 3 Total: 10
                          A controversial decision, but Vertigo wins. Well done Lewis.
                          So far, we have the following through
                          Overdrive, from England and entered by AJ!
                          The Eviscerator, from Wales and entered by Liam!
                          Fissure, from England and entered by AJ!
                          And from this fight, Vertigo from the UK and entered by Lewis!
                          Next time, Steel Sandwich will fight Hyper Ventilate and Toad will fight N3! See you then!
                          • #28
                            Welcome back to FRFFT! We have two middleweights next.
                            From the UK, Hyper Ventilate!
                            An odd design, basically two wedges with a lifting spike in the middle that can lift other robots up. Its invertible, but the wheels are exposed and how effective is it?
                            From Canada, Steel Sandwich!
                            A box wedge, the main weapon of this robot is its speed and front spikes which deliver a crumpling blow to its opponents. It is unreliable, though.
                            3-2-1: Activate!
                            Steel Sandwich looks very low to the ground, so this might help it here against the lifting spike of Hyper Ventilate. Hyper Ventilate pushes it from the side and slightly lifts it with the spike, but Steel Sandwich falls back to the ground. It turns to get under Hyper Ventilate, but Hyper Ventilate is first and gets the spike under one of the wheels! It lifts Steel Sandwich up and OVER! The wedge on Steel Sandwich is useless now. It backs away, but Hyper Ventilate is faster and RAMS it into the arena wall! Joey tries to get away, but Hyper Ventilate lifts it up and leaves it leaning against the wall! Lewis has done enough here, because Steel Sandwich isn't coming down from there. Refbot comes in.
                            What a shame. Steel Sandwich didn't really stand a chance, even with its low ground clearance. Hyper Ventilate still got hold of it. Hyper Ventilate hits the pit release button and goes over to Steel Sandwich, hitting it and knocking it free! It doesn't matter, though. Joey turns to get under the side of Hyper Ventilate, but it lifts itself off with the arm.
                            Cease!
                            Steel Sandwich passes its sell by date!
                            Hyper Ventilate goes through!
                            Sorry about the shortness of the fight. I wasn't feeling to motivated after writing the chaotic flipper frenzy, but I didn't want this to fall furthur behind
                            • #29
                              Welcome back to the FRFFT: World Championships
                              Next is a Superheavyweight fight between Drive, a two time champion, and newcomers Omega Rex
                              From the UK, Drive!
                              It might be a box on wheels, but it has eight drive motors and a wedge at the front to ram other robots around. Its invertible, but how effective is it?
                              From Wales, Omega Rex!
                              A six wheel box wedge with a powerful flipper. Its made from Hardox, but once the Co2 runs out, this robot could soon be extinct!
                              3-2-1: Activate!
                              Drive is the faster here, but it needs to avoid that flipper of Omega Rex. Drive turns and pushes into the side of Omega Rex. It gets under and OHH! It RAMS Omega Rex into the wall. Omega Rex recovers and chases after Drive. Drive turns again to face the side of Omega Rex, but Omega Rex does the same and gets under Drive. OHH! Drive THROWN into the air and CRASHES back down to earth! Did that do any damage? I don't think so. Its still moving, and gets under Omega Rex from behind and pushes it into a CPZ. No house robots, but Liam gets away. Drive presses the pit release button. Down goes the pit. Omega Rex bashes into the side of Drive and pushes it towards the wall! Drive goes FLYING, but comes back down inside the arena and not outside! Its still going, but for how long? Crashing into the side of Omega Rex again and pushing it into the wall, but Omega Rex flips itself free. What a fight this is. Drive hits Omega Rex again and pushes it towards the PIT! Omega Rex backs away just in time, but gets under Drive and OHH! It FLIPS and Drive goes tumbling into the pit. Omega Rex has snatched the crown away, but for how long?
                              Cease!
                              Drive crashes and burns!
                              Omega Rex goes through!
                              So, we have our first two finals.
                              Hyper-Ventilate VS The Eviscerator
                              Omega Rex VS Uberforce 2.0
                              See you later
                              • #30
                                What a shock. Drive, the superheavyweight champion is out. Will any more shocks follow? Next, we have another featherweight fight.
                                From the UK, Micrompression!
                                A box shape with two claws on the front, Micrompression competed in FRFFT Series Two. Its invertible and fast, but has a high ground clearance at the back.
                                From Wales, Small System Shock!
                                A box with tracks that pushes other robots around. Its invertible and has strong armour. How damaging will be be, though?
                                3-2-1: Activate!
                                Both robots are similar in design, but with different styles of attack and weaponry. Small System Shock turns to get around the side Micrompression and pushes it towards the flame pit! Micrompression recovers and tries to grab hold of the sides, but Small System Shock gets away. Lewis pushes Small System Shock aside, instead. Small System Shock, I'd say is on top at the moment. It chases after Micrompression, but now Micrompression turns around and OH! It pushes Small System Shock towards the wall and the claws grab hold of it! Small System Shock, though, has been built for traction and speed, so it pushes Micropression back! Lewis won't give in though! He lets go, but tries to get under Small System Shock with the wedge. Small System Shock gets under with its wedge and pushes it towards the CPZ. Micrompression turns towards the pit release button! Down goes the pit. Small System Shock pushes from behind, but Micrompression breaks free. It turns again and this time gets the claws around the side of Small System Shock! Small System Shock can't get away. It can only move on one side and swings around madly. Micrompression holds its grip on it, but the Hardox armour of Small System Shock is standing up it it. It lets Liam's robot go and gives chase, pushing from behind. Small System Shock nudges it, but Micrompression retaliates by turning around and pushing it towards the wall! Small System Shock pushes back as well, and Micrompression ALMOST goes into the pit! It grabs hold of Small System Shock again, but Small System Shock has far more traction and rams Micrompression into the wall! The last ten seconds count down. Micrompression lets go, but Small System Shock pushes it again over the flame pit. Micrompression gets away and nudges Small System Shock from the side.
                                Cease!
                                Two evenly matched robots. But only one can go into the final. The judges will make their decision.
                                Micrompression: S: 2 C: 2 D: 1 A: 2 Total: 7
                                Small System Shock: S: 2 C: 2 D: 0 A: 2 Total: 6
                                Its controversial, but Micrompression wins. Well done, Lewis! Bad luck to Liam, though.
                                See you later. More tactics are welcome for the finals
