Re: FRFFT: The World Championships
Welcome to FRFFT: The World Championships! First up, we have a featherweight battle between 360 and Overdrive.
As usual, there won't be any house robots except Refbot.
From the UK, 360!
Entered by Joey, 360 is basically a smaller version of Hypno-Disc, but still as dangerous. The disc can cause heavy damage, but it is light, and could be pushed around.
From England, Overdrive!
Entered by AJ, this robot is a box on wheels that rams its opponents and pushes them around the arena. Its fast, but how effective will it be?
Roboteers, stand by!
3-2-1: Activate!
What a way to begin the World Championships! 360 spins up and tries to get around the side of Overdrive, but AJ turns to push 360 from the side! OH! And into the wall! The disc has stopped spinning! Overdrive tries to push it again, but 360 backs away. Overdrive gives chase, but 360s disc has spun up to full speed. Overdrive charges in...OHH! Sparks fly and Overdrive is spun away a bit. No damage, the armour is quite strong. 360 comes in again, but Overdrive just charges head on again. It pushes 360 to one side but gets clipped by the disc. Joey gets away to the centre of the arena. Overdrive goes...where is it going? The pit release! It presses the button, down goes the pit. 360 needs to avoid that and chases after Overdrive. Overdrive doubles back and hits 360 again! Pushing it around and ALMOST into the pit! 360 gets away. Overdrive pushes from the side and onto the flame pit. 360 gets away again, but Overdrive pushes back. It's faster, Overdrive, at 15mph. Is the disc on 360 still working? Its spinning slowly. Now, Joey pushes Overdrive around and into the wall. Overdrive gets away and turns to push 360 toward the CPZ, but 360 turns away. I think all this pushing around has slowed 360 down. It turns around, but Overdrive is relentless and pushes it into the wall again! Joey tries to get away, but Overdrive pushes from behind and towards the PIT! 360 on the edge! Overdrive pushes again and OHH. Down goes 360! What a fight! Unlucky, Joey. Well done to Overdrive.
Cease!
360 in the pit.
Overdrive goes through to the final!
Sorry if that was short and a bit uncreative. Its been a while since I've written anything.
Liam, I assume your robors are represnting Wales. Are you still here?
Joey, where is everybody? Just wondering.
From the UK, 360!
3-2-1: Activate!
Cease!
360 in the pit.
